Generator on Atomic 4 ? - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 11-11-2006
Culinary411 is on a distinguished road
I'm running an Atomic 4 in my Cal 27 and was wondering if anyone knew of a way to mount a generator to it to maximize electrical output. I currently have a high output alternator but was looking for something more.
Culinary411
Old 11-13-2006
tenders is on a distinguished road
For anything beyond a high-output alternator, because of space in the boat and limitations of the crankshaft bearings making it difficult to run really large loads off the auxilary output, it will ultimately be much easier to use either a cheap inverter or a Honda portable generator.
I chose the inverter option (see harborfreight.com; mine is 3000 watts and cost $160); it took two hours to install counting me crimping my own power cable fittings. It runs a heat stripper and a small shop-vac simultaneously. I have the stock 35-amp alternator on my A4 and of course it is a huge drain on the batteries, but it works.
Harborfreight also has a 10kW generator head waiting for a 20+ HP engine to attach to it -- if you look at it you'll realize it will never fit in your boat.
The Honda generators are powerful and quiet enough to be considered engineering marvels but storage and maintenance complexities, plus carbon monoxide fumes, turned me off.
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
Atomic 4 fuel economy grumol Gear & Maintenance 6 12-05-2006 03:14 PM
Atomic 4 Studs TerenceONeill Gear & Maintenance 2 04-06-2003 12:12 PM
Atomic 4 bootsy1962 General Discussion (sailing related) 2 09-11-2001 02:12 PM
Atomic 4 Slow forward Jeff Gallo Gear & Maintenance 5 07-11-2001 09:26 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
