Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 11-18-2006
dinkum1 dinkum1 is offline
dinkum1 is on a distinguished road
Send a message via AIM to dinkum1 Send a message via MSN to dinkum1 Send a message via Yahoo to dinkum1
Engine/Drive Train Noise
We recently purchased a 1975 Bristol 27' with an Atomic Four. During
our initial cruise we noticed that at RPMs above 600 there was a
knocking sound. This sound is not heard with the engine running in
neutral or increasing the RPMs while in neutral. With the engine in
forward gear and upon acceleration (more than 600rpms) the knocking
sound becomes apparent and increases as the rpms are increased.
Question: Does anyone know if this is normal for the Atomic Four or
Bristol 27 or if there might be a particular problem that needs to be
addressed? Any input or help would be appreciated. Thanks.
Michelle and Harley
Old 11-29-2006
tenders tenders is offline
tenders is on a distinguished road
Not normal. What happens in reverse? Could be, in order of severity: something fouled on the propeller, spark plug wires on wrong spark plugs, badly misaligned timing, loose zinc on the shaft near propeller (happened to me once), loose propeller, loose coupling between shaft and engine, misaligned engine causing shaft wobble, bent shaft, broken transmission.
When hearing hooves, think horses before zebras.
Display Modes
vB code is On
HTML code is Off
Engine/Drive Train Noise dinkum1 Bristol 2 11-18-2006 08:11 PM
Autohelm noise lgsailor19 Gear & Maintenance 0 08-09-2004 04:28 PM
Growling noise around cutlass , or maybe packing or ???? obiec Gear & Maintenance 6 06-01-2004 01:18 PM
Generator Noise Oxley Gear & Maintenance 0 11-10-2003 08:20 AM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
