07-09-2009
The Indigo kit is neat, but in my experience it's not necessary...I would get a PCV kit from them first. What you may find helpful if you ever intend to haul the engine for repair or a paint job is tapping the oil pan and putting in a 90 degree elbow, a petcock and a short length of hose to a small hand pump. This gives you the ability to change the oil "white glove style" after a nice run to get it hot and easily flowing. Pump out the old, pour in the new, turn off the stopcock, and you're done. This and the "basket filter" between the water pump and the block are the two best modifications I've made, with the fuel/water separator and separate fuel shut-off mounted on the aft bulkhead coming after that.
Can't sleep? Read my countdown to voyaging blog @ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
