Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 08-10-2007
northstarjim northstarjim is offline
northstarjim is on a distinguished road
carbon monoxide
Hi, I had a problem with my A4 the other day I can't explain. It had been running fine all season. It is raw water cooled. During a cruise back to port, the sound of the engine suddenly changed, was running very roughly, and slowly an odor could be detected inside the cabin. I checked the carbon monoxide detector and it was reading 80 to 100 (first time ever it read anything higher than zero). I shut the engine off. Tried starting it again later but it would only idle with the choke pulled out - when closing the choke it would stall. After a few tries and pouring some Mystery oil in the tank, there was a pop and then the engine started running normally again. I'm a new A4 owner, so have a lot to learn - can anyone explain this? sticky valve???
Thanks
Old 08-10-2007
USCGRET1990's Avatar
USCGRET1990 USCGRET1990 is offline
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Interesting...try a post over hear, there's more engineering folk...
http://www.boatdesign.net/forums/
Old 08-10-2007
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura about
making a base assumption here.
highly doubt a sticky valve.
More than likely some gunga-munga in the fuel supply.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 06-19-2008
themcnasty's Avatar
themcnasty themcnasty is offline
Complete&Rudder Disaster
themcnasty is on a distinguished road
Carbon Monoxide would only come from your exhaust and that would only come out into the cabin if your exhaust system had a leak or gasket problems shot it out the side of the head/valve cover or backwards out the intake.
I would take a peak at the head gasket (probably the only gasket you can't replace with a cutout from a manila folder, so buy a replacement gasket before removing the head) and valve cover gasket. Also, if you don't already have one, run an air intake hose back to some storage compartment not in the cabin rather than just leaving the littler perforated breather thing on.
Display Modes
vB code is On
HTML code is Off
Carbon Fiber & Lightening Ronbye Gear & Maintenance 19 08-15-2008 04:01 PM
Conservation Group Petitions to Regulate Carbon Dioxide poopdeckpappy Off Topic 19 04-15-2007 09:17 PM
Tripp design 66' carbon fibre cruiser racer project alajuelacutter General Discussion (sailing related) 0 07-06-2006 11:36 AM
Carbon Monoxide Detector quinlanmw Gear & Maintenance 2 12-28-2003 06:34 AM
Carbon Monoxide on Board Sue & Larry Gear and Maintenance Articles 0 01-09-2002 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
