Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 06-17-2007
NorfolkRagbagger's Avatar
NorfolkRagbagger NorfolkRagbagger is offline
NorfolkRagbagger is on a distinguished road
Hose block fitting, RH btw w/pump & thermostat
On starting my recently acquired A4 (recently acquired boat with A4,) I saw considerable water coming out of a fitting (see image) on the RH side of the engine. The fitting is a "T" with a hose going to the thermostat and water pump.
I tightened the clamps on the hoses, no fix, then pulled the hoses off, found the problem was the fitting as it went into the block. The fitting is bronze, common, no big deal. Upon removing it, it was noticeably loose in the block, just about fell out due to the corroded insert area, then upon removal the plate that the fitting screws into literally crumbled; I almost sh*t, then noticed the fitting threaded into a plate. Glad it wasn't the block itself.
Corrosion is considerable and needs attention, but does anyone know here I could get the flat plate, about 4" tall, 12" long (wild guess on dimensions).
I hope it's clear what I'm referring to in the images.
This forum is an oracle of information. Thanks for any advise.
Well, scratch the pictures, I've checked sizes, etc, they're way below the size allowances, but I failed in the upload 5 or 6 times. If they will help, I'll find somewhere else to post them.
Got lucky! Posted the images here!: Welcome to your Personal Web Pages!
Thanks again.
Old 06-18-2007
ChicagoNewport27's Avatar
ChicagoNewport27 ChicagoNewport27 is offline
Purveyor of Fine Ideas
ChicagoNewport27 is on a distinguished road
Easy! That's a Water Jacket Side Plate:
http://www.moyermarine.com/images/689.jpg
You can get them at Moyer Marine, with or without all the fittings.
Water Jacket Side Plate at Moyer Marine (follow this link, then scroll down)
For more assistance, contact the experts at Moyer Marine (moyermarine.com)
Moyer Marine Atomic 4 Engine Rebuilding and Parts
Moyer Marine Forums
Old 06-18-2007
Water jacket side plate
Sometimes it's amazing how close you can be to finding something, if only you looked in the logical place! Thanks a million. I'd suspect Moyer Marine and I will be becoming quite familiar. Thanks again, you made my day (and likely the season!)
By the way, the Moyer Marine site is a Godsend. I find the community there for us "old" A4 owners to be outstanding. KUDOS to Mr. Moyer.
Last edited by NorfolkRagbagger : 09-16-2007 at 05:42 PM. Reason: Wanted to commend Bill Moyer.
Display Modes
vB code is On
HTML code is Off
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Marine Hose SailNet Miscellaneous 0 09-20-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
