Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
  #11 (permalink)
Old 01-05-2009
tommays's Avatar
I dont like to disagree with cardiacpaul
BUT if your going with and electric fuel pump it does need to be MARINE AND IT DOES need to be wired correctly so that it ONLY runs when your cranking and uses and oil pressure switch to keep it running after the motor starts
You also need to use real A1 marine fuel line
If you pop auto parts into a marine gas motor and it pops or burns you will have insurance issues and could end up killing yourself
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #12 (permalink)
Old 01-05-2009
hellosailor's Avatar
Gasoline fuel pumps tend to be "ignition" protected no matter what the application, land or marine. It isn't like alternators, where the marine models have additional vapor-ignition protection. I suppose a pump designed for the land market might have a nice aluminum casing which promptly pits away in salt air, but I don't think an insurer would bother looking all that closely at whether a pump was USCG approved, the claims value on any old boat with an A4 in it just isn't going to be all that high. (And the pump maker could be held liable in any case.)
I'd have to agree with cpaul, that's not one to lose sleep over. But like anything on a boat--and all too much of anything in stores these days--you need to eyeball it and see if it has been built right for your needs.
I'd disagree on the starting fluid, though. Flammable vapors below? No need, just spray the same areas with Windex or plain water, if the engine speeds up then stumbles it has ingested the spray. (Speeds up as the water blocks the leak, stumbles as the water gets into the cylinders.) Some mechanics also use propane from an unlit torch--which works the same as starting fluid, more or less. Still a flammable gas problem on a boat, I'd prefer the spray bottle.
USCG approved Windex, of course. (VBG)
  #13 (permalink)
Old 01-22-2009
elborracho is on a distinguished road
If you are on the west coast, I would be interested in buying your A4.
Bill
"Head-Mate" Seaclos Rebuild? SEMIJim Gear & Maintenance 12 08-12-2011 10:25 PM
MacGregor 21 rebuild Jolley Roger MacGregor 21 03-08-2011 12:43 AM
Rebuild vs replace diesel engine Ilenart Gear & Maintenance 40 02-21-2010 10:23 PM
Rebuild 2GM vs repower with 2YM15 or 2YM20 Northeaster Gear & Maintenance 18 04-03-2009 08:03 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 09:52 AM
