Start A4 while on the hard? - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 03-24-2009
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
Forgive my naive question, but can an Atomic 4 by started while a boat is on the hard? I'm assuming they are water cooled, which presents a problem while on the hard. But is there a method of attaching a water hose to run test it out?
I'm considering the purchase of a used boat with an A4 that hasn't been run in 3-4 years. Among many other potential issues, I'm concerned about the A4's condition. Before I spend the money on launching/sea trialing the boat, I'd love to know if the A4 runs.
Old 03-24-2009
not Sully or Dandelion
MorganPaul is on a distinguished road
I have done it many times. Remove the hose that goes to the threw hull, put the hose into a 5 gal bucket of water. The bucket should be down at about the same level as the engine. And keep the bucket from going empty by constantly feeding fresh water into it.
Old 03-24-2009
RanAweigh's Avatar
Sea Dweeb
RanAweigh is on a distinguished road
Here is a link to a PDF copy of the manual
http://www.cncphotoalbum.com/atomic4manual/a4manual.htm
Is you engine raw water cooled or Fresh water cooled? The procedure is slightly differnet.
If fresh water cooled:
1. Close raw water thru-hull valve
2. Check oil
3. Check coolant in heat exchanger (1" or so below filler neck)
4. Run a hose from the raw water "T" valve into a bucket of fresh water
5. Check that the raw water "T" valve to the bucket is closed
6. start engine
7. check oil pressure
8. When the 5 gallon bucket empties (in about a minute) shut down the engine.
Old 03-24-2009
kwaltersmi's Avatar
Broad Reachin'
Thanks guys! That's exactly what I was looking for.
Old 03-24-2009
CLucas's Avatar
CLucas is on a distinguished road
Send a message via AIM to CLucas
Very important! Do not crank the engine with the hose in the bucket of water or you risk getting water in places it shouldn't be (the cylinders, specifically). When the engine catches, THEN place the hose into the bucket.
I would also suggest checking the condition of the impeller first (among other things) -- it if hasn't been started in 3-4 years, it could be in pretty bad shape. If a vane or a piece breaks off and gets lodged in the cooling system, you'll have some work ahead of you.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
Old 03-24-2009
That indeed is good advice.
And I would not put the engine in gear. Make sure it is in neutral.
Old 03-27-2009
Pretzel is on a distinguished road
Why would this cause any problem? When the boat is in the water, isn't that like having the hose in the bucket?
How does the water get into the cylinders from the cooling system?
Old 03-27-2009
Here is a quote from Don Moyer. Found here:
Much much water in Atomic 4 [Archive] - Moyer Marine Atomic 4 Community
1) The most common way for water to get into the cylinders of an Atomic 4 is for cooling water to back up within the exhaust system by over-cranking the engine with the raw water through-hull open. Without the engine running and producing exhaust pressure to move the cooling water out through the exhaust system, water will continue to collect within the system until it reaches a level that enables it to flow back into the manifold. From there, the water has a direct pathway back into the combustion chambers.
Old 03-27-2009
CLucas's Avatar
MorganPaul beat me to it. When the boat is in the water, the best practice, especially if some time has elapsed since the engine was last started or if it is likely to crank for more than a few seconds before catching, is to leave the thru-hull CLOSED while you crank the engine and OPEN it after it catches. That way you're sure not to overload the exhaust system with water and then the cylinders, etc.
It goes without saying that you should close the raw water thru hull (and any others) when you leave the boat. Some people put little reminders (a label or even hanging the key on the valve itself) to remind them to open it after it's started.
BTW, Pretzel, welcome to Sailnet.
s/v Grey Goose
~~~~~~_/) ~~~~~~
Old 03-27-2009
Valiente's Avatar
It, or rather the antifreeze/fresh water mixture, will siphon back into the valve chambers if you crank without the engine catching (see above). The A4 can run "dry" for a couple of minutes from cold if you are just attempting to start it. You can even plan for this.
When you replace the impeller (and after four years on the hard, you WILL want to do this...and get a circ-clip pliers to make life easier), you will want to check for leakage at the pump body-to-block gasket, and you will need to find "pump grease", a waxy sort of hard grease like beeswax, to put in the pump shaft lube port (the little screw-on cap you periodically tighten). If you don't have this, a thick blob of lithium grease will do, but won't last as long.
When you fit the new impeller, grease that entire area with lithium grease as it will keep the new impeller nice and slippy for the short period you intend to run it dry, as it is the water itself that keeps the vanes supple.
Start the engine (you should already have put in new spark plugs, check the spark wires, checked the coil and distributor connections and made sure the batteries are serviced and charged and that you've got a new alt. belt on that is properly tensioned. You also better hope that the fuel system was COMPLETELY drained and the carb was fogged or otherwise cleaned and that the gas is completely fresh and the tank vent isn't a spider condo. But I digress.
Once the engine's running, in neutral, watch the gauges to see if the alt is charging and the oil (which should be fresh and "pre-cranked" by hand into the cylinders) is at 25-40 PSI. Watch the temp gauge. It can go from 100-150F without harm, but that could take five minutes in neutral, so you have plenty of time to drop a hose into a bucket once you've got it running. It helps to have a second person to handle the bucket to catch the old antifreeze, to read the gauges, and to stop or start the engine while you run this checklist (and it's only partial).
My point is that there are several ways in which an Atomic 4 won't start or will look like junk when it isn't...someone just forgot to do the right thing.
Can't sleep? Read my countdown to voyaging blog @
Hard dodger GoodOldBoat Gear and Maintenance Articles 8 04-03-2010 10:48 PM
Can I put VC-17 over hard bottom paint? Finallybuyingaboat Gear & Maintenance 3 11-02-2008 11:42 PM
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 13 04-09-2008 01:12 PM
looking to start and need advice johnniespaceboy General Discussion (sailing related) 9 03-20-2008 05:11 AM
Cruising with a Hard Dingy on Davits LWinters Cruising & Liveaboard Forum 6 12-27-2006 09:32 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
