Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 05-04-2010
Justa
Location: Strasburg, Virginia (I need more work near the 'Neck')
seaspot is on a distinguished road
A4 alternator?
I need a new alternator for my A4 and after seeing how much they are, I started wondering if any of you all have used a different alternator on your A4?
An AC Delco off of many GM will fit, internal regulator, single wire hook up, and cheap.
Even a marine one for a Mercruiser would work and still cheaper than the one for the A4.
Has anybody else already done this?
Old 05-04-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Is your old alternator really shot? A good alternator rebuild shop should be able to fix your old one if it is just a diode or two that are shot. The problem with a rebuild is that it can cost as much as $250 to have your alternator rebuilt and a new 55 amp alternator from Moyer Marine is only $217.50. The original alternators on the A4 are only 35 amps so a new 55 amp alt. may just be the way to go.
Moyer Marine Atomic 4 Engine Rebuilding and Parts
Or try an AC Delco alt. but you should not need much more then 55 amps of output. The higher the amp rating on an alt. the more power it uses from the engine to generate those amps.
I have priced some 'marine' alternators and I agree that they are very $$$. It usually pays to shop around and compare prices/products.
Good luck whatever you do.
Old 05-04-2010
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
I had my 35A alternator totally rebuilt into a 55A alternator by a local Baltimore shop. It cost less than $100 for the rebuild, so I'd definitely look around and get some prices from a local alternator/starter shop before committing to buying a new one.
S/V Free Spirit
Monrovia, MD
Old 05-05-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
If yours is shot why not try to repair it yourself.Usually brushes if em,.\.,m
Old 05-05-2010
tommays's Avatar
What ever you do PLEASE use the marine unit as the brushes are spark shielded to help with BOOM
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-06-2010
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
PLEASE - take it to a rebuild shop.
Brushes are about 12 bucks, diode pack about 15, and regulator about 20.00
(along with a diff diode pack and regulator, can make the prestolite, or motorola, or the delco to push out 50 amps.)
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
Old 05-06-2010
Justa
OK, I;ll bring it back with me this weekend and have a local guy check it out and see what he'll charge to rebuild it.
I was just a little shocked when I looked up how much the replacements were.
Old 07-11-2010
Justa
Just an update. The alternator was wrecked internally and was not able to be rebuilt.
Since I have tons of ventilation in my engine compartment, I just went with an AC Delco, one wire alternator. 80 amps, with core exchange, I just gave them an old GM I had sitting around, $29.99 out the door.
Hooked it up and I now have a ton-o-charging.
Old 07-11-2010
Bad idea to go with an automotive alternator. IIRC, they are not ignition protected...and as such are an ignition source for explosions on a gasoline powered boat.
Old 07-11-2010
Justa
If there are fumes sure. The main difference is just the internal screen, which the old A4 alternator didn't have anyway. I figured that out when I took it apart.
