Atomic diesel... - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 06-02-2010
calden's Avatar
calden is on a distinguished road
Atomic diesel...
Hey all:
Looking at a Catalina 27. The seller says the engine is an Atomic diesel. I can't find much about Atomic diesels. Anyone hear of them?
Thanks,
Carlos
Old 06-02-2010
Early Universal diesels were labeled as "Atomic" Diesels. I suspect it's one of those.
1984 Fast/Nicholson 345
Old 06-02-2010
calden's Avatar
Faster - thanks for the fast response. Reputation on these?
Thanks,
Carlos
Old 06-02-2010
r.furborough is on a distinguished road
Atomic diesels from Universal (now a part of Westerbeke) were based on Kubotas excellent engines. Once the Universal model # is known the Kubota model # can be established and none marinization parts bought a lot cheaper. Unfortunately parts like the exhaust manifold/elbow are Universal only parts and are expensive.
Old 06-02-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
The above posters are correct. It's a Universal diesel based on a Japanese Kubota industrial engine. For a Catalina 27, I would bet it's a model 5411. Main issue with those engines is that they are raw water cooled and can have overheating issues after years of use in salt water. Good news is that parts are readily available - expensive from Universal/Westerbeke and reasonable from Kubota or other non-marine sources.
Old 06-02-2010
deniseO30's Avatar
Lies about her age
I've a universal 5416 in my 1982 O30 it's the first diesel I've ever had and keeps running and running and running and running... PO said he replaced it with the exact same engine with a good used one but I have no way to prove it other then it's painted white and obviously has been removed/replaced. Most all diesel problems are air, fuel, and water related.
Old 06-02-2010
Gary M's Avatar
Gary M is on a distinguished road
I had a 2 cylinder Universal diesel in a boat I bought new in 88. That model had a heat exchanger so some of them did, must have been an option.
As far as I know they were as good as most diesels, I believe at least some of the models were meant to be a direct replacement for the A4.
Old 06-03-2010
JimsCAL's Avatar
The 5411 was raw water cooled. The 5416 and larger were fresh water cooled with heat exchangers. My speculation that it's a 5411 is based on that Catalina put the 5411 in the Cat 30 for a number of years. Unlikely they would put a larger engine in a smaller boat.
Old 06-03-2010
SeaFever2000 is on a distinguished road
Agree with the comments above. Some of the earlier Diesels from 'Medalist - Universal" were often termed Atomic diesels, mostly in conversation. I have not seen many spec sheets that show them as Atomic Diesels but have read literature referring to them as such. Most if not all of the Universal diesels are based on Kubota blocks and are very reliable in my experience.
I myself have replaced my Atomic 4 gas engine with a Universal M25 recently and am very happy. I get most of my parts from TractorSmart.com or from a local Kubota dealer. All you need to do is find out which Kubota bolck your engine is based on and then find a Kubota part list for that engine. My M25 is based on a Kubota D-850 block.
I am pasting a excerpt from the "History of Universal engines". IT will also tell you which Kubota blocks these engines are based on.
If you ever have any difficulty finding a part for any Universal engine, feel free to PM me.
Hope it helps.
"The first Universal diesel was advertised in 1976. Designated the Model 5416, it was a 45 cu in, 16 hp, 2 cylinder, based on the Kubota Z-751 block and built from 1976 to 1982. Approximately 1,000 were sold. It was replaced by the Model M20, which was produced in 1982 and 1983. Approximately 230 were sold.
In 1977 the Model 5411 was introduced. It was a 31 cu in, 11 hp 2 cylinder raw water cooled diesel, based on the Kubota Z-500 block, and fitted with a Hurth transmission. The 5411 was built from 1977 to 1982. Approximately 2,900 were sold. It was replaced by the Model M15, which was produced in 1982 and 1983. Approximately 370 were sold.
The Model 5424, a 68 cu in, 24 hp, 3 cylinder, based on the Kubota D-1101 block, was built from 1977 to 1983. Approximately 1,050 were sold. It was replaced by the Model M-30, which was produced from 1983 to 1987. The Model M-30 was the same size, but later M-30 engines were based on the Kubota D-1102 block. It was built from 1983 to 1987. Approximately 400 were sold.
The Model 5421, a 52 cu in, 21 hp, 3 cylinder, based on the Kubota D-850 block, was built from 1978 to 1981. Approximately 1,000 were sold. It was replaced by the Model M25, which was produced from 1981 to 1986. Approximately 3,650 were sold. It in turn was replaced by the Model M-25XP, a 57 cu in, 23 hp, 3 cylinder, based on the Kubota D-950 block, built from 1986 to 1999. Approximately 3,100 were sold.
The Model 5432, a 91 cu in, 32 hp, 4 cylinder, based on the Kubota V-1501 block, was built from 1978 to 1982. It was also called the Atomic diesel. Approximately 650 were sold. It was replaced by the Model M40, which was produced from 1982 to 1998. The Model M-40 was also a 4 cylinder model, and the same size at 91 cu in and 32 hp but it was based on the Kubota V-1502 block. Approximately 360 were sold.
The Model 5444, a 115 cu in, 44 hp, 4 cylinder, based on the Kubota V-1902 block, was built from 1980 to 1982. Approximately 280 were sold. The Model 5444 was replaced by the Model M50, which was built from 1982 to 1997. Approximately 520 were sold."
Old 06-03-2010
Originally Posted by SeaFever2000 View Post
.... Some of the earlier Diesels from 'Medalist - Universal" were often termed Atomic diesels, mostly in conversation. I have not seen many spec sheets that show them as Atomic Diesels but have read literature referring to them as such. .
It actually said "Atomic Diesel" on the engine control panel in at least one case I've seen.. and I believe there's a picture here on this site somewhere...
Informative post, btw, SFever!
Dr. Diesel, Foley Engines, and me... skipgundlach Diesel Engine Forum 34 06-13-2011 07:00 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 08:00 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 08:00 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
