-   Atomic 4 (http://www.sailnet.com/forums/atomic-4/)
-   -   The Joys of winterising (http://www.sailnet.com/forums/atomic-4/68687-joys-winterising.html)
CaptianKirk 09-29-2010 03:46 PM
I am going to be pulling my boat for the winter in about a month and I am wondering what I should be doing to the motor for the winter. It is a Palmer p-60 gas motor. I know I should add anti-freeze, but is there anything else?
JimsCAL 10-03-2010 08:10 AM
With any engine being put away, an oil and filter change is needed. Also change the fuel filter. Is the engine raw water or fresh water cooled? Procedures are slightly different for each, but basically flush and drain the raw water system and fill with Boat/RV antifreeze.
CaptianKirk 10-03-2010 09:46 AM
mmmm, I am confused by the question is raw water and fresh water not the same? It is not salt water, but water from the lake. I always call that raw water. There is not a heat exchanger on it, if that is what you are asking.
I am just wondering how to ensure that all of the water is out of all of the nooks and cranny inside the head?
fordo 10-03-2010 10:25 AM
Raw water is the water that comes from outside your boat, fresh or salt. The "fresh" water is the mixture of antifreeze and water that flows through the engine cooling it and then is, in turn, cooled by the "raw" water in the heat exchanger. If you do not have a heat exchanger your engine is cooled directly by the raw water.
To winterize the engine fill the fuel tank with stabilized fuel. This is especially important with the alcohol in modern gasoline. Run the engine to make sure the stabilized gas is through the system, especially the carb or injectors.
Change the oil and filter.
For the cooling system you must replace the raw water with RV(non-toxic) antifreeze. I do this on the hard by running a piece of tubing from the intake side of the waterpump to a gallon of antifreeze. Start the engine and run it until you have run two gallons through the engine or heat exchanger and the muffler.(This should also run the stabilized fuel through the engine.)
Then, if you have a gas engine,(not diesel) remove the spark plugs and spray a little oil into each hole. Crank the engine a second or two to coat the cylinders with oil. Replace the spark plugs and you are done.
kwaltersmi 10-26-2010 08:07 AM
You may also consider pulling our your water pump's impeller. Some impellers are susceptible to damage from antifreeze exposure. Besides, it's a good time to check the condition of the impeller.
