12-01-2010
The A4 is a simple engine. Good automotive machinists are able to do just about anything that comes in the door as the basic principles are the same. The only thing they have to have are things like bearing and piston clearances plus torque specifications and there are databases of engine manuals available online for that. The fact that you live in a place that does commercial boats is to your advantage. Large diesels are very expensive to rebuild so these folks have to get it right or the problems with guarantees will drive them out of business. Talk to some of the commercial boat owners and see whom they recommend. Also, a machine shop can usually get parts at almost manufacturers prices so check with them about parts prices before you order anything. If time is a problem, see if they will do a long block where the head and covers such as pan, valve side cover and timing chain cover are removed and installed by the shop. One additional advantage of this is cleanliness, very important on a rebuild. On a long block you will have to remove the accessories such as water pump, filters, alternator, etc.
