01-29-2011
Needing Apehanger Helm
After being in the Hogg bissness over the years ...you would be suprized how many COILS are "bad in the box" this is not to say a bad one wouldnt start & run an engine ... Just that new in box mesurements with the correct meters I found 1 in 14 that was perfect ...and yes the store will sell all of them , go figure....
Plenty one can do to a cap & roter bug to make them better parts ... but would take wayyyy to long to say here ....just to be simple here .. keep an old cap cut it in half or so just so you can see the bug strike buy the pole & allways pick a bug that comes closer to the pole without hitting it ...
Plenty of little things to do to help old type engs....if you can find another bug that fits great and has same dim. ( even tho it is for another eng) it may have a longer arc shaped striker play with it and you might be suprized how well your eng runs with it ...normally this would add + or - timeing by 2-4* and a longer spark burning time for better fuel burn...just make shure the burn doesn't continue into the intake valve opening phase..
Ok thats enough info to help most & to get the rest into trouble ,,,, after all these are simple engines and playing with them and knowing them will go a long way to helping them.....after all thay were mass produced & everything was left short & loose just for that reason ( which doesn't mean we cant clean some of that up )
For the ppl who think everything was designed and built as close to perfect as possible when produced ....Disregard this post your mindset can't be changed lol
There is no right way to do the wrong thing
