06-13-2011
Senior Culinary Member
You may consider replacing with a PSS Shaft Seal, but it may be tight. You would want to call them before with some measurements.
There's a lot of corrosion there? I wouldn't doubt if you have to cut the shaft to get the coupling off, which means a new shaft, coupling, and either new stuffing box or shaft seal.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
