Changing Oil - Page 2 - SailNet Community
 3Likes
post #11 of 31 Old 09-18-2011 Thread Starter
I ran it for 2-3 minutes. Sounds like I need to let it completely warm up. Correct?
Thanks,
Scott
Scott Vickery is offline
post #12 of 31 Old 09-18-2011
mitiempo's Avatar
That should help.
Brian
mitiempo is offline
post #13 of 31 Old 09-18-2011
Tartan 27' owner
CalebD's Avatar
Yes, warming the engine up makes the oil more liquid (viscous) and easier to pump out. You may have other problems though if there is not enough oil to pump out from the dip stick hole - even if the oil is cold it just moves slower through the pump. I also use a 12V Jabsco oil pump and even cold oil will get sucked out.
You should carefully check your oil dipstick to see what level the oil is at. The easy way to check the oil level is to take a clean paper towel or rag and wipe the dipstick down, then re-insert it and pull it out. Lay it up against the clean paper towel or rag and you will be able to see at what level the oil registers on the stick by the stain on the towel or cloth.
If you are just low on oil I'd advise getting a few quarts of cheap oil to put in and then run the engine for a bit and then pump out what you can. Check the color of the oil; dark is not good and milky is even worse. Dark oil just means that the crank case is dirty and needs a few oil changes to clean it out. Milky colored oil indicates that water has gotten into your crankcase; the cure for this is also several (3) subsequent oil changes to get most of the watery oil out of the engine. Also running the engine until it gets up to temperature after the oil changes helps get the remaining water out.
These old engines like fresh oil (change every 50 - 100 hours of use).
Use a good oil like Rotella T 30W oil to fill the engine after you have used cheaper oil to flush out the muck and/or water.
Good oil is cheap insurance.
Good luck.
Everybody has one:
CalebD is offline
post #14 of 31 Old 09-19-2011
Scott, in my warped view of the universe all the mechanical oil removal pumps are junk. Electric ones, drill powered ones, all junk.
We bought one of the vacuum-bottle ones and I love it. Pump up a vacuum in the cannister, stick the hose in the oil dipstick tube, open the valve and
s l u r p
it very slowly but surely all comes up.
The fly in the ointment is that you now have about three feet of oily curly plastic hose that wants to whip about and scatter oil all over you cabin, so you wipe it down with paper towels as you remove it, and store it in double plastic garbage bags because there's always some oil mess waiting to break out.
But the damned things work wonderfully.
hellosailor is offline
post #15 of 31 Old 09-19-2011
tommays's Avatar
About the best place to get out ALL the oil is tapping a 3/8 npt plug into the transmission cover
Due to the angle the motors are installed and lack of oil filter I found the sediment settled in this area over the years
Brewgyver likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #16 of 31 Old 09-22-2011
Tundra Down
downeast450's Avatar
Tommays,
Two questions about your picture. It is really that easy to pump out all the oil from a hole in the transmission cover? Really? I will do that mod and work from back there if that is all it takes. I am wondering about the zirk fittings? on your water pump couplings.
Thanks,
Down
downeast450 is offline
post #17 of 31 Old 09-22-2011
tommays's Avatar
The Oil comes right out if it is warm as i use the same pump on inboards that suck up the oil through the dip stick the 3/8 NPT hole will take a 3/8 metal tube which allows a lot of oil to pass
That is the new Moyer pump with the quick change cover and i used two ball valves on it as i do not wish to drain the FWC anti-freeze every time i need to change the inpeller
downeast450 likes this.
Tommays
Northport NY
tommays is offline
post #18 of 31 Old 09-22-2011
Tundra Down
Thanks,
Is the cover plate thick enough to tap directly or did you have to add something?
Down
post #19 of 31 Old 09-22-2011
tommays's Avatar
It took a NPT tap fine you have to pick your spot as i have to turn the transmission a bit to get the tube past the clutch pack
Tommays
Northport NY
tommays is offline
post #20 of 31 Old 09-23-2011
Tundra Down
Thanks again.
I will add a plug this season while TD is on the hard. I still have only 23 hours on my 3 year old Moyer rebuilt. Mostly back and forth from launch / haul and maneuvering in close harbors. We can sail onto and off of our mooring. It is time to replace the oil because of its age if nothing else.
Down
Tags
atomic4 , change , oil
changing of the guard justice General Discussion (sailing related) 5 09-09-2009 06:31 PM
Which oil changing pump is best? LJD Gear & Maintenance 24 08-11-2009 08:35 AM
Changing the channel ReadyToSailJo Crew Wanted/Available 1 03-28-2009 07:08 AM
Changing Halyard Gulfislander Gear & Maintenance 7 05-13-2007 11:22 PM
Changing Rigging Sonofasonofasailor Boat Review and Purchase Forum 6 12-06-2006 06:51 PM
