Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 09-18-2011
jimmoser is on a distinguished road
A4 Clutch & Throttle Control Replacement
Catalina Direct: Clutch and Throttle Control Retrofit Atomic 4
I'd appreciate thoughts on this replacement. Twice now, while coming into a slip the bracket holding the clutch cable slipped leaving me with no choice but to turn off the engine while in very tight quarters. Needless to say, some paint was lost while we wrestled the boat into the slip sans engine.
I see alternative as replacing the cable, so the added cost over that would run about $200 which seems reasonable if the contraption works.
Old 09-18-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
So, it would appear that you have wheel steering as that throttle/shift control is meant to fit on a binnacle or steering post. Catalina Direct has a decent reputation for their parts.
They may be able to supply you with the cables for the throttle and choke if they need to be replaced as well. Another source for the choke/throttle cables is: Moyer Marine Atomic 4 Engine Rebuilding and Parts
Engine throttle control Greguk Boat Review and Purchase Forum 1 03-08-2010 01:15 PM
Throttle question ... should _I_ have to control idle myself? scraph Diesel Engine Forum 5 02-21-2010 07:23 AM
Help! I am going crazy with my Teleflex Throttle Control. What is t NewsReader Mass Bay Sailors 0 07-06-2006 08:15 AM
shift/throttle control firemanbob55 Gear & Maintenance 3 07-29-2005 06:29 PM
Throttle/Shift Control oldsaltydog Gear & Maintenance 2 01-02-2002 10:14 AM
