-   Atomic 4 (http://www.sailnet.com/forums/atomic-4/)
-   -   My simple oil change pump (http://www.sailnet.com/forums/atomic-4/80233-my-simple-oil-change-pump.html)
tommays 10-29-2011 02:06 PM
http://i565.photobucket.com/albums/s...1_10290017.jpg
Mr Goodpump Jr which has amazing suction
http://i565.photobucket.com/albums/s...1_10290022.jpg
My custom cover hole which allows about 95% of the oil to be sucked out
Ajax_MD 10-29-2011 02:09 PM
Awesome!
Southcoasting 12-13-2011 10:27 AM
I'm guessing you "tap n dyed" this custom hole so that you can close it back up with a screw? If not, can you explain a bit more?
MarkSF 12-13-2011 05:07 PM
I can see the dipstick in shot. Why not go through the dipstick hole?
tommays 12-14-2011 02:53 PM
The dip stick does NOT go to the bottom of the pan like a modern motor and sucking out oil through a 1/4 OD of 1/8 ID tube is really slow
The motor is mounted at a REALLY steep angle and when i had it out and in the shop that is were the oil pools
All the built in holes will not get much oil out as there placed for a more level install
