01-15-2012
Tweaked?
If it is just adjusting the "morse" cables and cable detents, that's probably 1/2 hour to an hour of labor, which could be $50-125 an hour plus travel time or minimums.
If no one has looked at the cables in a long time, it may be more extensive, the cables may need replacement, etc.
But if the only tweaking it needs is routine adjustment on the cable mechanism, that's the kind of thing you might want to try with a helper abovedeck to work the lever for you while you're below. Should be in a manual, not a big mystery, but if the guy is reasonable and you're unsure, ask him to show you how it is done, in case something comes loose while you're not at the dock.
