I just finished my first season as a boat owner, and had her hauled for winter the last day of November (a beautiful day for sailing, I'm sorry to say.) So now I'm gathering up instructions for winterizing my Atomic 4, and of course I'm seeing several common steps that required running the engine. Oops. Good learning point for next year.
But for this year, any advice on how to proceed? I'm on the Chesapeake in the Baltimore area, so I expect some freezes, but nothing crazy like they have further north.
To be clear, I am NOT interested in running the engine on the hard using some sort of cooling workaround, unless someone convinces me I have to. Oh, and by the way, I'm also second guessing whether I need to have her hauled for winter at all.
This engine has fresh water cooling if that makes a difference.
Absolutely must run antifreeze through the fresh water cooling system. Not a hard job. With my boat I just disconnect the intake hose from the through hull and suck up a few gallons until the exhaust runs a pretty pink. Same with any water lines in the boat. Drain you fresh water supply put a couple of gallons in and pump through. Don't forget the holding tank, head and bildge lines as well. Prevention is cheaper that fixing a cracked anything. Again not a hard job and doesn't really take that long. Use the same antifreeze used to winter an RVs systems.
Itchy and Scratchee,
I have owned a raw water cooled A4 for 10 years now up in the NY area. When you say your engine is 'fresh water cooled' that usually means you have a heat exchanger (HX) with a cooling circuit of anti-freeze and another circuit of raw water which requires two water pumps. Raw water cooled engines have no anti-freeze circuit and only one water pump.
-If you keep your boat in the water on the Chessy it will likely be warmer than if you had it hauled onto the hard. The water temps rarely get below 32F down there.
-Raw water intake and HX need to be winterized on your 'fresh water cooling' system. The anti-freeze or 'fresh water' circuit obviously does not need to be winterized. I usually do this by running the engine long enough to suck in a gallon or 2 of RV antifreeze. If you don't want to run the engine then I'd suggest draining all raw water cooling hoses, the HX raw water side, remove water pump impeller to allow water to drain out and figure out how to drain your exhaust system. I'd guess an air compressor might help with some of this to help force the water out.
- fog the cylinders. This step involves putting an ounce or 2 of Marvel Mystery Oil or equivalent 'fogging oil' into the spark plug holes in the top of the engine/head. Once the oil is in there I usually turn the engine over to spread it around. The engine does not have to actually start to accomplish this so the spark plug wires could be detached for this step.
The best A4 advice I have found on the web comes from the Moyer Marine forum. There are several A4 owners from the Chessy who post there.
If you want a good A4 mechanic to show you what to do this winter I'd recommend Will Sibley who lives around Shadyside, MD.
Yes, Caleb, that's what I meant when I said "fresh water cooled." I understood the need to fill the raw water circuit with antifreeze, but I was hoping to find a relatively simple way to do it without having to run the engine.
And by the way, my hesitation about running the engine was primarily about having to do it with no external cooling water. Is this even a concern? If I was to just run it long enough to do the job with the raw water and antifreeze...is that doable?
Perhaps I am a little confused. Correct me if I am wrong.
- Your boat is still in the water and you are considering having it hauled out?
- If your boat is still in the water you could run the engine as per normal, no?
- Closing your raw water valve seacock and removing the hose to stick into a bottle of anti-freeze is not your idea of fun?
- If you are already hauled and on the hard cooling water may be a bigger deal. You can still get away with running the engine for short periods without any cooling water. By short periods I mean a minute or two, perhaps 5, but don't take my word for it because I run my engine on land with a 5 gal. bucket fed by a hose for cooling water. I can run it almost as long as I like.
The only worry I have about running an engine on the hard, is the vibration when on the stands. Maybe borrow an extra pair or two and be sure you have them chained across.
I would not worry about the cooling at all. While I'm not very familiar with the A4, I assume the fresh water coolant has a thermostat, which won't even warm enough to open by the time you're done.
The sure fire way to get the job done is to pull the hose off the raw water seacock and stick it in a bucket of antifreeze. If there isn't enough slack, then just get another couple of feet of hose and a coupler. If your strainer is above the motor, as mine is, you can just pour the antifreeze into it with a funnel or large hose. Gravity should remove the raw water from the strainer to the thru hull in that case.
If this is your first year, make a checklist and write everything down that you do. It will make planning much easier next year and winterizing will take half the time.
Caleb, I've already hauled the boat. After it was blocked, I started looking at the winterizing procedures. A mistake that I won't repeat next year! As far as using a bucket of antifreeze, no problem. But I read a while back about rigging a substitute water source for running an engine out of the water, and that is what I was trying to avoid (unless absolutely necessary...I don't mind the work if required!) But it sounds like it's not required after all.
Minnewaska, thanks for the information. I'm thinking I'll go ahead and do the normal run-and-drain as you described, taking extra precautions with the stands if required.
Scratchee, that clarifies your situation quite nicely. Thanks for that.
Instead of re-inventing the wheel I should point you to the winterization procedures as laid out by Don Moyer (of Moyer Marine) here: Winterizing your Atomic 4 - Moyer Marine Atomic 4 Community - Home of the Afourians
I'll also recommend you get the A4 owner's manual that Moyer sells.
If you have a seawater strainer on your engine thru hull, all you need to do is open it up, have a buddy start the engine while you pour a couple of gallons of AF into it. Shut off the engine and you're done. No strainer, then stick the hose into a bucket as suggested above.
Caleb, I'm happy to say the boat came with two different manuals for the A4, one from Moyer and one original. All the material I've read has complete instructions for winterizing in the water BEFORE hauling. As I said, a mistake I won't make again next year.
Chuck, thanks for the advice. I'll come back here and either report a properly winterized engine, a seized engine with a cracked block, or a boat that fell off the stands due to the vibration! :laugher
Scratchee,
Don't sweat it. You have the manuals with their winterization procedures laid out. The main thing for you to address is the raw water side of the engine so you don't freeze your HX. Oil change can be done in the spring.
My first winterization of the A4 was incomplete at best and ours survived despite my shoddy work. I believe that our impeller got frozen and lost a few vanes the first winter. I now like to remove the impeller so this does not reoccur.
Learned from the school of hard knocks and dirty socks: DO NOT run your engine on the hard in anything but neutral! Finding neutral on the A4 can take some patience and fine tuning.
If you didn't do that, then I highly suggest doing one before you fire up for the anti-freeze. You will have to draw cold oil, which may take longer, but will work. When you fire up for the antifreeze, you will circulate the new oil over that minute or two. Old oil will have lost its protective qualities and have contaminants that allow corrosion. You want fresh oil when sitting over the winter. Again, it will lose its protective qualities just sitting there, so change it again when you relaunch. Some have trouble with changing oil that has not been run, but it does not last just sitting in your crankcase. Its very cheap preventative maintenance.
Many will pull their impeller after winterizing, which is a good idea. However, I never use mine more than one season, so I leave it in for the winter and change it when I launch.
Alrighty then. My raw water circuit is full of anti-freeze, my oil is drained, and my boat did not fall off the blocks. So not a bad afternoon at the yard.
I did think about the starting in neutral thing. What's the concern there? Vibration? Dry packing? Being alone, I considered parking my truck so I could see the prop in the mirror, but finally I just did it with the stick in "SBN" (Should Be Neutral) and hoped for the best. Total run time was probably less than two minutes.
I drained the oil--very VERY slowly--but did not refill per Moyer. On the other hand, I didn't run it with the Marvel Mystery Oil after draining, like he said. Over the next few weeks I'll spend some more time on things like draining the carb, etc, and can run some MMO. Primarily I was interested in protection from freezing, so I wouldn't have to sit at work when the temp hit 28, wondering what was happening to my engine.
Thanks for all the advice. It was not only appreciated, but helpful.
The concern of running the engine in gear on the hard is much as you have laid out. The packing gland is designed to have water present to lubricate the shaft. No water = no lube. Same goes for the Cutless bearing. Vibrating the drive train for no good reason is also not a good idea. I know what you mean about the "SBN" shifter setting. Neutral is a very elusive spot with most A4 trannies.
I'd suggest that you at least dump a quart of Marvel Mystery oil in the engine. If you have a hand crank for your engine you could use that to move the gears around inside to distribute the oil. MMO has rust inhibiting qualities which is why I use it to lube the cylinders before putting the engine up for a rest.
Not recomended because usually the strainer is located close to the engine in a tight place and you will either spill or not get the antifreeze in fast enough into the stainer basket. Plus you arent getting the water out and replacing with antifrezze oin the hoze leading up to the strainer which could turn to ice and then crack the hose.
Caveat- One of the sure fired ways to destroy an impeller is to run it dry for any length of time. In the spring one of my yearly maintainence checklist items is to always replace the raw water impeller. Peace of mind
Chef, that's pretty much exactly what I experienced. My strainer was mounted in a tight spot, while the through-hull was right there and easily reachable. I just undid the hose and stuck it into a jug of antifreeze. Didn't even need a bucket!
Thanks again Caleb. I'll definitely head back out with some MMO.
You're welcome Scratchee.
I know that you will be better prepared the next time around. It took me some time to learn about my A4 too. The Moyer forum and store has made owning an A4 an overall positive experience for me and taught me a lot more about engines than I had originally intended. The high cost of 'professional' help to do the work was another incentive to learn how to do it myself. The right tools, curses, luck and you can keep your A4 running smoothly without paying someone else to do it.
"The sure fire way to get the job done is to pull the hose off the raw water seacock and stick it in a bucket "
Actually, for the lazy sailor with a small hose...you can install a t or y valve, put a screw cap on the unused side of it to make sure it can't leak, and add six feet of garden hose (unscrew cap, screw on garden hose) when you want to suck antifreeze from the bucket. Less than twenty bucks and that way, you don't have to pull any hose off any fittings every winter.
A lot of home plumbers used air compressors to winterize home plumbing. The air won't blow everything out of every trap right away but if you le it run for a while, it gets most of the raw water out, and after a while the "breeze" will suck more out, leaving a system with enough room for freeze expansion, etc. if it isn't totally dry. $100-200 for a cheapie compressor or $25 to rent one for the day.
Can't you just drain both systems?
Do they have drain plugs?
Related Threads
1.7M posts
173.8K members
Since 1990
