$6,600 to rebuild Atomic 4? replace/rebuild - Page 5 - SailNet Community
 39Likes
post #41 of 69 Old 03-31-2013 Thread Starter
Re: $6,600 to rebuild Atomic 4? replace/rebuild
Thanks Sloop,
I already had the crank ground down, and purchased the appropriate sized bearings to accommodate the new size. I bought a set of engine brushes, so I plan on going through the motor with them and ensuring all the gunk is clear and no remnants of glass are present. As for the rod honing, I'm not familiar with this procedure...the mechanic suggested that I hone a few pieces of the motor during the rebuild, but I haven't researched the specifics on this yet.
Thanks for the feedback, as for Porfin's posts, I have already gone through them several times and will definitely use his documentation as a guide in my rebuild...he did a great job outlining his rebuild!
-Chris
simmonct is offline
post #42 of 69 Old 03-31-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by simmonct View Post
Thanks Sloop,
-Chris
Resizing the rods involves having the cap mating surfaces ground down slightly to make the big end slightly "football" shaped, then they hone it to perfectly round again at the original factory diameter. To do the wrist pin end (small end) they ream the hole and press in bushings that also bring the hole to original factory specs.
We're talking thousandths of an inch here.
The reason for doing it is because the strains on those components are largely "linear" along the rod so the holes tend to get slightly elongated along the long axis of the rod - again, thousandths of an inch but that's what you're dealing with in an engine - precision really counts towards power and longevity. That's why they call it "blueprinting".
SloopJonB is offline
post #43 of 69 Old 04-03-2013
sunfish?junior?
Good deal letting us see how its going. This is a hard crowd at times but in this case we are cheering for you ! Kind regards ,Lou
Lou452 is offline
post #44 of 69 Old 06-27-2013 Thread Starter
Well, I thought I would just close the loop on this thread and give a quick update...
I am very happy with my decision to take on the project. The money I saved is not even close to the enjoyment/education I gained from the job. It was not without it's fair share of bumps and curve balls, but I am happy to say that the motor is back in the boat and has been running better than ever. I happened to run into the mechanic during my (delayed) launch and he complimented me on the reassembly...I told him Moyer did it.
Thanks for all the feedback and insight, couldn't have done it without ya!
Chris
simmonct is offline
post #45 of 69 Old 06-27-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Good deal, it is always fun to learn new stuff.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #46 of 69 Old 06-27-2013
Tartan 27' owner
CalebD's Avatar
My Atomic 3 or 4 and the Moyer forums have taught me a lot about wrenching my own engine.
Glad you enjoyed the trip!
Everybody has one:
CalebD is offline
post #47 of 69 Old 07-15-2013
You should talk to Don Moyer at Moyer Marine. If you call him up and speak to him directly you are likely to get a fair answer and price. He has given me excellent free and unbiased advice in the past and his company is the reason why I am keeping my A4 and am not repowering. I somehow never trust boat yards.
tominny is offline
post #48 of 69 Old 07-17-2013
JimsCAL's Avatar
???? Did you even read the thread before you posted?
JimsCAL is offline
post #49 of 69 Old 10-27-2013
Congrats! I have done a bunch of the Moyer Mods, but an encouraged by your post that I may one day be able to do the same.
Quinn99 is offline
post #50 of 69 Old 10-28-2013
Tartan 27' owner
CalebD's Avatar
Quinn99,
Have you signed up for the Moyer Marine forums yet?
Great forum about the A4.
Everybody has one:
CalebD is offline
Tags
atomic 4 , atomic 4 engine , c&c , diesel swap , engine rebuild
Gibsea 43' Rudder Rebuild/Replace Help jkemp Gear & Maintenance 4 11-02-2012 06:45 AM
Rebuild vs replace diesel engine Ilenart Gear & Maintenance 40 02-21-2010 11:23 PM
Replace vs Rebuild? chtaylor Atomic 4 12 01-22-2009 11:08 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 10:52 AM
REBUILD or REPLACE bombero Gear & Maintenance 0 11-22-2000 06:55 AM
