$6,600 to rebuild Atomic 4? replace/rebuild - Page 7 - SailNet Community
 43Likes
post #61 of 74 Old 07-14-2014
Boat shopping
Re: $6,600 to rebuild Atomic 4? replace/rebuild
Yea the $4k went to Moyer. The thing that sold me on the exchange engine was that it was painfully obvious that my engine was horribly neglected and the Moyer engine came with all the updates. It came with electronic ignition, the electric fuel pump, the oil changing kit, the furled extensions on the water pump cover, just about every upgrade they offer on the site comes on the exchange engine. Not only that, I got a new starter, new carburetor with all its little extras. Add that up on the site and the deal gets even better!
I removed the engine myself and got it out into the cockpit and had the yard take that down and place the new engine onto the motor mounts. They charged me $50! So, it was really a nice engine swap and a refresh on the engine room. after seeing the mess in the thermostat housing, the Fresh Water cooling kit from Indigo was a no brainer. I also threw the external thermostat housing and she runs a very nice 175 to 180 degrees!
I have to say, Yesterday was the best this engine has ever run. i installed the Indigo prop. I gain a little drag but the engine really likes the prop! It was a great day on the Viking!!! 15 knots of wind 6-7 knots thru the water on just the head sail! We had some issues that delayed the beginning of our season so it was our first time out this year. Great great day!
Danny
Boat Shopping
South Coast, MA
SloopDogg is offline
post #62 of 74 Old 07-14-2014
christian.hess's Avatar
its a deal when you get that back...a no brainer!
congrats
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #63 of 74 Old 07-28-2014
Tundra Down
downeast450's Avatar
We did the same thing for the same reasons! Love the Moyer exchange. A sweet engine.
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #64 of 74 Old 08-15-2014
Mark: I have installed rebuilt Atomic IV in Catalina 30, but took the cable connection apart on port side to lubricate large tranny cable. Lost my photo on this assembly so do you or anyone have a photo of cable connection at cockpit control lever which is inside port lazarette??? Would be so grateful for photo or diagram.
catadmire is offline
post #65 of 74 Old 12-27-2016
I have a great A4 for sail,,oil seals and bearing replaced 300 hour ago, I am changing the boat to diesel {got 1 for free} at this time I am changing out hoses and toching up paint. Call henry at 860-836-9797 if interested
hransom is offline
post #66 of 74 Old 12-27-2016
travlin-easy's Avatar
My A4 was rebuilt by Moyer in 2001, still runs like a Swiss watch, so quiet that most folks cannot hear the engine when we are down to idle speeds. And, not only is gasoline significantly less expensive than diesel in this part of the country, but less dirt. My diesel friends change fuel filters several times a year and those filters are nearly plugged each time. I changed my gas filter three years ago and while I carry three spares onboard, I think I will likely get another three years out of the filter before it needs changing. Plus 1 on Moyer's rebuilds! They do a great job and the prices, while high, are not nearly as high as a similar size diesel rebuild.
Now, one thing that every A4 user should know. There is a product out there called Marvel Mystery Oil, which keeps these old engines running forever and really works well in reducing wear and improving valve seating. I know there are skeptics on this site when it comes to this product, but those of us that are A4 owners and users swear by this stuff, and so does the folks at Moyer Marine. You will find the product at most auto parts stores in the US.
Good luck,
Gary
Barquito and oldlaxer1 like this.
travlin-easy is online now
post #67 of 74 Old 12-29-2016
chef2sail's Avatar
Good luck,
Gary
I had an A4 for many years on my first boat , an Islander 28. Was a great engine , reliable , easy to fix. Moyer was a great resource. As Gary said...champion of gas engines. I certainly had a love relationship with my old one.
So we have had for many years now had a Yanmar Diesel. It's the little engine that could. Clean fuel, easy to change the filters, easy to work on, no smell. Great mileage Very reliable. Mac Boring also a good resource.
If I had a choice from the jump....I choose the Yanmar. Let's face it....something to be said about not worrying about fumes blowing us up
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #68 of 74 Old 12-29-2016
So, 7 pages and nobody has mentioned anything about stelite and installing new seats in old engine. Not the usual back yard job so figure the expense in proper rebuilding
Capt Len is online now
post #69 of 74 Old 12-30-2016
In reality, the chances of blowing up because you have a gasoline engine onboard is probably less than blowing up because you have a propane stove onboard. Keep in mind that 99 percent of all the recreational boats in the US are gasoline powered, and most of the explosions take place as the result of doing something stupid while refueling, such as leaving the engine running, or not turning on the bilge blower before restarting the engine. According to the last boat US report I read about marina fires, they were the result of an electrical problem, or someone placing a heater onboard in a bad location.
Now, I was watching Deadliest Catch on the Discover channel a few months ago and one of the boats experienced a cracked fuel injector line, which triggered the explosive gas alarm. The diesel fumes were so thick that the mechanic had to wear a respirator and hazmat suit in order to get to the shut off valve and facilitate the repairs. They also had to use a special, sparkless fan to evacuate the fumes from the engine room. Fires aboard diesel-powered commercial fishing boats are not at all uncommon, and there have been many resultant explosions.
Another source of boat explosions is the result of shorted batteries that are on chargers or being charged while underway with the alternator. I experienced this first hand while fishing at the Marquesses Keys many years ago. At the time, I owned an 18-foot Starcraft Mariner, center console fishing boat powered with a 75 HP Johnson outboard. The battery was housed in a compartment beneath the transom well and accessed via a sliding door. That was also where all the electrical connections were made on an open terminal block and the relay for the power tilt and trim was housed. Apparently, the battery developed a shorted cell, thus causing the alternator to overcharge the remaining cells and produce a large quantity of explosive gasses. The explosion occurred when I activated the power trim as I entered the flats near Boca Grande Key. The blast blew the sliding door completely off the transom, sounded like a grenade going off and scared the hell out of the other two anglers in the boat as well as myself. Fortunately, we were in the company of another boat that had a spare battery that allowed up to clean the boat up and get back to Key West.
For many years, I've written about and advocated an automatic bilge blower than must be activated for at least three minutes before the ignition switch can become operable - just makes sense. I have also been a big proponent of constant ventilation in the battery compartment when the batteries are under charge, either at the dock or while underway.
Good luck,
Gary
post #70 of 74 Old 03-12-2017
Originally Posted by simmonct View Post
I just received a quote to rebuild the Atomic 4 motor on my 1979 C&C 34. I was shocked at the $6,640 price tag for this job and I asked them to hold off on the repairs while I consider alternative options.
During haul-out this season, it was noticed by the yard crew that the motor was creating knocking sound and I ordered the engine be pulled from the boat for inspection. A few weeks later I received a diagnosis of the problem...here is what they said:
"There was a bad connecting rod that was causing the banging. Also the cylinders are worn out and need to be bored out and larger pistons & rings installed. Along with a bad exhaust valves, bearings and valve guides."
They are suggesting a total engine rebuild. I am concerned that the value of the boat does not warrant such an investment and was hoping to get some feedback from the SailNet community.
The engine needs some work, I understand that, but is a rebuild my best option? I plan on selling the boat in about 3 years for an upgrade, but I can't use/sell the boat with a compromised engine.
Questions:
-Do I ask them to repair the connecting rods and handle the minor repairs myself?
-Do a full rebuild?
-Go all in and do a diesel swap? (hoping that I can extract 50% value when I sell)
-Look online for rebuild motor and have yard install?
Any insight, thoughts, words of wisdom, etc... would be appreciated. Thanks for reading!
-Chris
I just purchased a complete engine in brand new condition from Moyer Marine. $6075 less $700 core charge refund for my old Atomic 4 engine from my 1973 Catalina 27.
I made the trip from Glen Burnie, MD to their machine shop in PA.
The engine is emaculate.
Capn Ben is offline
Tags
atomic 4 , atomic 4 engine , c&c , diesel swap , engine rebuild
Gibsea 43' Rudder Rebuild/Replace Help jkemp Gear & Maintenance 4 11-02-2012 05:45 AM
Rebuild vs replace diesel engine Ilenart Gear & Maintenance 40 02-21-2010 10:23 PM
Replace vs Rebuild? chtaylor Atomic 4 12 01-22-2009 10:08 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 09:52 AM
REBUILD or REPLACE bombero Gear & Maintenance 0 11-22-2000 05:55 AM
