Raw Water Valve/Impeller Confusion - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 04-09-2013
S/V Glenn E
Lubrdink's Avatar
Re: Raw Water Valve/Impeller Confusion
Thanks Fast. That's encouraging.
"Sailing with a hero"
Honoring S/Sgt Glenn English, Jr, Congressional Medal of Honor for heroism that cost his life in Viet Nam, 9/7/70.
Newport 27 built 1970-Hull # N270088
Lubrdink is offline
post #12 of 14 Old 06-03-2013 Thread Starter
Sorry to bring back an old thread, but there has been some progress. New oil, plugs, gas (87 octane- couldn't get the non-ethanol this time!), and racor filter. Now that the choke is free, it fired up and ran pretty well. Sounded GOOD, and no signs of smoke. Pumped 5 gallons of water in less than a minute. Took forever to find neutral, though. THE ONLY possible weird thing I can find so far- the prop shaft is LOUD when it turns. It sounds like a tires making a tight turn in a parking garage, if that makes any sense. Wiggled the prop, and there is very little play.The shaft even makes noise while turning it manually. Will this noise subside when I splash it? It doesnt seem to be coming from the back of the engine, more like from the stuffing box or cutlass bearing. I hope this isn't bad- hoping to splash this week!
FirstCandC is offline
post #13 of 14 Old 06-03-2013
Stuffing box is dry.. you should notice an improvement in the water after a while. In the meantime I'd not run it that way any more.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
FirstCandC (06-03-2013)
post #14 of 14 Old 06-03-2013
tommays's Avatar
The rubber cutlass bearing MUST BE WET
Its the one outside the boat that supports the prop shaft
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Changing A Raw Water Impeller (How To) Maine Sail Gear & Maintenance 42 10-30-2014 01:52 PM
Raw Water Pump Impeller casey1999 Diesel 14 01-24-2013 01:34 PM
Raw water impeller Hobos Gear & Maintenance 2 09-14-2008 08:10 AM
raw water impeller change davidcms Gear & Maintenance 5 09-07-2008 01:22 PM
Sea Water Pump Impeller nauticalrich Gear & Maintenance 3 03-19-2003 09:20 AM
