Raw Water Valve/Impeller Confusion - SailNet Community
 1Likes
post #1 of 14 Old 04-02-2013 Thread Starter
I realize you are supposed to start the A-4 and THEN open your water intake valve, but doesn't that cause damage to your impeller? On every outboard I have ever flushed, the manual states that you should always have water coming in prior to starting.
Also, how long should you run the engine before opening the valve?
Thanks.
FirstCandC is offline
post #2 of 14 Old 04-02-2013
Re: Raw Water Valve/Impeller Confusion
If you are confident the engine will start almost immediately, then you can open the seacock before you start and your impeller will thank you.
If, on the other hand, the engine doesn't actually catch in the first few seconds of cranking, then you should shut the RW off as you continue attempts to start - you should open the through hull immediately after the engine is running.
downeast450 likes this.
Faster is online now
post #3 of 14 Old 04-02-2013 Thread Starter
Thanks. The one time that it did start, it really pulled a lot of water out of the bucket, so I guess the water pump is doing ok.
post #4 of 14 Old 04-02-2013
MikeOReilly's Avatar
I've never heard that you should start an Atomic-4 before opening the water intake as standard practice, and I owned one for nearly 10 years. Never did that. If you're having troubles starting, where there is a risk the cooling water can fill the muffler and then back up into the cylinders, then yes, shut off the intake. But that's only if the engine is turning over (and not starting) for a while: more than 30 seconds I would think, depending on your exhaust system's setup.
Starting the engine without water lubricating the impeller will cause it to wear. If you're having to run without coolant (water) for a while, then you could take the impeller out.
Why go fast, when you can go slow.
MikeOReilly is offline
post #5 of 14 Old 04-02-2013
tommays's Avatar
If the motor is not firing in about 3 seconds its BROKEN and that is on a COLD DAY
The manual choke lets it pull in fuel very EASY
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #6 of 14 Old 04-02-2013 Thread Starter
The choke is stuck- I mean REALLY stuck. Going to try to fix that this weekend, and change the oil, gas, etc.
BTW Tommays you are my HERO, I love your blog.
post #7 of 14 Old 04-02-2013
One of None
deniseO30's Avatar
I think the A4 uses the Oberdorfer pump. when it comes to replacing the impeller DO NOT get the blue ones from Globe they are too short. GET OEM Oberdorfer.
jus sayin...
My last project!
deniseO30 is offline
post #8 of 14 Old 04-03-2013 Thread Starter
Noted!
post #9 of 14 Old 04-09-2013
S/V Glenn E
Lubrdink's Avatar
I'm going to replace my impeller for the first time this week. We ran the A4 last year after purchase so not sure how long it's been since it was replaced. Does anyone know if, under normal wear and tear, whether the impeller will pull off easily or will it require a puller? I hope the former but want to be prepared just in case.
Thanks,
"Sailing with a hero"
Honoring S/Sgt Glenn English, Jr, Congressional Medal of Honor for heroism that cost his life in Viet Nam, 9/7/70.
Newport 27 built 1970-Hull # N270088
Lubrdink is offline
post #10 of 14 Old 04-09-2013
The impeller should not need a puller, but if its been there a while you may need to use a couple of screwdrivers to pry the impeller straight out.. Remember to protect the gasket surface of the housing if you need to resort to this.
Changing A Raw Water Impeller (How To) Maine Sail Gear & Maintenance 42 10-30-2014 12:52 PM
Raw Water Pump Impeller casey1999 Diesel 14 01-24-2013 12:34 PM
Raw water impeller Hobos Gear & Maintenance 2 09-14-2008 07:10 AM
raw water impeller change davidcms Gear & Maintenance 5 09-07-2008 12:22 PM
Sea Water Pump Impeller nauticalrich Gear & Maintenance 3 03-19-2003 08:20 AM
