A4 Overhaul - First Start - SailNet Community
post #1 of 3 Old 05-26-2013 Thread Starter
Hello, I just completed the assembly of my A4 after an overhaul. I am ready to attempt my first start after the rebuild and wanted to get some tips/pointers from the Sailnet community.
One question, I am looking for a manual oil pressure gauge to install for tuning...any suggestions? Preferably something available at an AutoZone.
Also, I don't have a fancy setup (as I've seen on YouTube, etc)...does anyone have any suggestions for a basic setup that will allow me to start/stop/tune the motor while on the bench?
Thanks for your thoughts!
-Chris
simmonct is offline
post #2 of 3 Old 05-26-2013
Barquito
Barquito's Avatar
Re: A4 Overhaul - First Start
Cool. Hope the re-start goes well. You could use a cheapo from Harbor Freight (Engine Oil Pressure Test Kit), or permanently install one from Moyer on the engine (Moyer Marine Online Store). Just some ideas.
Valiant 32
Barquito is offline
post #3 of 3 Old 05-28-2013
tommays's Avatar
Pretty much any gauge will fit right into the 1/8 NPT pressure sender spot with a 1/8 male X 1/4 female fitting
You just need a jumper wire from the battery to the coil and I find a push button starter tester better for turning over the motor than jamming in a screwdriver
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Tags
atomic 4 , overhaul , rebuild
Rudder Overhaul ranes Gear & Maintenance 52 12-19-2015 01:12 AM
Caliber 40 Refrigeration overhaul loyola Caliber 3 04-15-2013 11:58 AM
Overhaul Cost haukebo Gear & Maintenance 15 12-18-2006 04:18 PM
DIY diesel overhaul jeffb General Discussion (sailing related) 2 12-09-2005 06:03 PM
winch overhaul jasonsiriska Gear & Maintenance 5 04-04-2002 06:29 PM
