Thanks, good to hear. I have not discussed this with the owner yet - but my wife wonders how "dry" a boat it is. I told her it should be pretty good - relatively speaking - for a 24 footer....
Dry is a relative thing...depends on how big the waves are
The height of the aft cabin should keep the spray down a bit. The boat is going to heel easily initially and then firm up, probably at about 15 degrees. There is a little bit of tumblehome in the hull shape which tells you that this is a boat that is comfortable sailing on its beam. As it heels, the boat's waterline lengthens appreciably and it gains speed.
The Paceships were designed specifically to sail on the Atlantic coast, and they are pretty safe boats for their size. You won't be winning many races but you won't be the slowest boat out there either. They have a seakindly hull shape and will not slam up and down on the water the way the newer, more performance-oriented boats with the flat bottoms will.
Note that you're going to find yourself listening to the swing keel as it moves around in it's trunk when you're in light winds on a swell. It should not be much more than a gentle "thunk" though, so you probably won't find it too annoying.
If the boat has been decently maintained, you could do far worse for a first boat.
Reagardless of what you end up buying, make SURE you have it surveyed, with special attention paid to the swing keel, chainplates and rudder fittings. These are the important parts.
Don't blow off a survey thinking that it's a "cheap boat" and it's not worth investing the extra dollars upfront. There could be things wrong with it that the current owner is not aware of, and he/she may be unknowingly selling something that is less than seaworthy. The ocean doesn't often give second chances, so get it right the first time.
Good Luck ! Let us know how things work out.
