01-26-2010
My in-laws used to live down there... right on the water, and I'd point out that most monohulls are going to have a problem in 3.2-4' of water. In water that shallow, I'd recommend getting something with less than 2' of draft... Not too many monohulls are going to fit that description.
The reason I say you want to have that much clearance is that one of the worst things you can do to a boat is to have it bouncing off the bottom. With any kind of wind and fetch, a boat with a 3' draft is likely to bottom out regularly.
Most of the boats you're looking at are going to be tiller steered. Most smaller, shallower draft boats are tiller steered. Part of the reason for this is simple—the steering linkages take up space, and you need a deeper hull for a wheel steered boat in many cases.
One boat that might fit the draft criteria is the Westerly Nomad 24. It has a draft of 2.25' or so. However, this is a triple keel boat that can dry out (ie can stand on its own keels) and it will tend to be fairly slow because of the extra drag from the multiple keels.
Most small catamarans, like the Heavenly Twins 26, would also fit the bill. As would a lot of the sport trimarans, like the Corsair 28/31, Telstar 26/28, Dragonfly 820/28/920...
However, the sport trimarans will tend to be a bit out of your price range is my guess, based on what Catalina 27's go for.
