Originally Posted by BarryL
Hello,
Why did you rate Newport so low? I owned a Newport 28
I just found where I got my prejudice against the Newport 28.
Practical Boat Buying Volume 1 page 239
"Make no mistake about it the Newport 28 is a boat built to a price. A common complaint by owners is mediocre fitting of woodwork, leaking hull-to-deck joint, cockpit drains that are too small, plastic valves on through hulls, inadequate backing plates in short the entire litany of problems associated with boats built to be low in price."
They sold well about 1,000 because it was a good design however.
Do you think that was unfair to say that about the Newport.
Actually you bring up another variable.
A manufacturer can spend (1970 dollars) another $300 to put in a teak and holly sole but save the same money on labor by rushing or using less skilled people.
Since this thread is about quality not features or design if that is what happed to the Newport they would get a lower rating in my system.
Since you owned the boat you should be in a good position to judge if my rating is fair according to my system.
My thinking about redefining best as based quality only is on the idea that anyone can go on a boat and see if they like the dinette layout, the shiny sole or extra wide cabin. What they may not know is that a particular boat has a reputation of being cheaply build and hastily assembled.
Which may not be a problem on an old boat as the problem may have been fixed.
