04-19-2010
Each deal will be different but here is what I would suggest and have done.
If the boat is on the hard I did not require a sea trail when I made my offer, nor a survey. In fact I preferred the boat being on the hard. Think carefully about what a sea trail is going to tell you and look at the boat with that in mind.
If you are unable to determine if the seacocks are in good condition while on the hard then I would say they are not. Same is true for other items on the boat. You wonder if the rigging works, again inspect it, if mast is on raise sails or at least halyards and so on.
To me this is not more time consuming than a sea trial as I would do these inspections even if the items did work.
The engine can be run on the hard, most everything can be inspected more easily on the hard than in the water.
Yet there are things that a splash will reveal, most would have to be fraudently hidden to not be seen in a good inspection.
Then there are those custom boats. The cookie cutters (mass produced boats) are always easier to inspect as you would have looked at (or at least I did) many even dozens of identical boats (when they were built anyway). This enables you to compare apples to apples.
I found custom or old one offs are the hardest to judge. A survey will help but there can be lots of major problems no one is aware of. I did not buy one of those because the owner sees nothing but a great boat, I see nothing but risk, and since I could not afford a mistake we could not agree on price. They should be sailed as the mast (and other items) may well be in the wrong spot and the owner just got used to it.
I ran away from deals in which it appeared I needed to cover my butt because I was unable to see items or there seemed to be the likelyhood of fraud or lets just say inconsistencies in the story and the item being sold.
All deals have deception, even going through a broker. Your job is to discover them. Find any other than the usual and acceptable then walk away from the deal.
As for items included I would suggest everything seen is included. Take lots of pictures. I got ripped on that, minor issue but still there. When I said all boat stuff remain I expected all boat stuff to remain. The person cleaning out the boat (owners son) decided that meant all boat stuff bolted down remained. He only took a few items I would have preferred to remain so I said lesson learned. The next boat seller will wonder why I'm including pics in the contract but a pic can save a thousand words.
Sellers that have items on the boat that are not include in the sale should not be given the same credit as the seller that has properly prepped the boat.
But as I said each deal is a little different, if you do not feel comfortable inspecting a boat yourself, or do not have time, or are spending so much money that others have something in the deal then I would suggest making an offer with a small amount down to show you are serious and then complete the transaction after all inspections, surveys, and trials.
Cleaner clearer deals are better than complex ones but complex is sometimes needed.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
