Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Boat Buyers & Sellers Forum
Old 05-02-2010
Volkhard's Avatar
Volkhard is on a distinguished road
For sale: 1998 Island Packet 37
Bluewater capable cruising yacht, cutter rigged,in mint condition with extensive refit in 2007/2008 is for sale in Annapolis. The boat will be ready for showing and pictures mid May.
Start your cruise in Annapolis this summer and go South for the Winter!
For more information, visit Wix.com - Website built by volkhard based on Lifestyle Mentor
Florida Sailor
ODYSSEY
Island Packet 37 (hull53)
Old 05-11-2010
Volkhard's Avatar
If this is the wrong spot for a member to offer his personal boat, please remove my post or redirect my post to the more appropiate section of our forum. I had no intention of wrongdoing!
Florida Sailor
ODYSSEY
Old 05-11-2010
JohnRPollard's Avatar
Moderator
Volkhard, You're fine. But I will move this thread over into the "Boat Buyers and Sellers" forum. I know, I know -- it's a bit confusing how we have this set-up.
One further suggestion is to maybe have a more text-based advertisement or spec sheet that prospective buyers can link to directly. I followed your link but had trouble navigating when I got there and didn't see any real info on your boat.
Old 05-12-2010
Volkhard's Avatar
John
Thank you so much to put it into the right spot.
When it comes to my website, you should be able to navigate from the homepage by clicking the tabs :
photos/factory specs/equipment/price/contact
just right of
Island Packet 37
Model 1998 hull 53
If your please could try again and let me know?
It works without problems on my PC, on my laptop and on my computer at work
Thanks
Florida Sailor
ODYSSEY
Old 07-04-2010
Volkhard's Avatar
Odyssey is finally ready to be shown!
For info go to Wix.com -1998 Island Packet 37 for sale
Location at this time : Annapolis, MD
ready to go South any time.
Florida Sailor
ODYSSEY
Old 07-07-2010
Volkhard's Avatar
Basic boat description Island Packet 37
Hull # 053
Classification Category A Ocean
LOA 38'5" or 11.70 meter
LOD 36'5" or 11.10 meter
LWL 31'.0" or 9.45 meter
Beam 12'2" or 3.70 meter
Draft 4'6" or 1.37 meter
Mast above DWL 49'6" or 15.10 meter
Fuel capacity 50 gal(US) or 189 liter
Water capacity 90 gal(US) or 341 liter
Holding tank 12 gal(US) or 46 liter
Headroom 6'4" or 1.93 meter
Displacement (approx) 18,500 lbs or 8,409 kg
Ballast 8,200 lbs or 3,727 kg
Sail Area 800sqft or 74.3 m2
Main 284sqft, full battened
Genoa 384 sqft on roller furling
Staysail 132sqft, self tending, rollerfurling hoist boom
Ratios
Sail Area / Displacement 18.3
Displacement / Length 277
Ballast / Displacement 44%
Engine 38hp Yanmar 3JH2E
Engine hours (approx) 2350 (May 2010)
Transmission KBW 10E
Cabins / Berth 3 / 7
Head / Shower 1 / 1
Construction
Solid (no core) Fiberglass construction with Triaxial roving for the hull.
Cored Fiberglass construction with Poly Core for the deck, cabintop & cockpit.
Integrated laminated Fiberglass construction for the bowsprit.
ISO/ORTHO/NPG premium gelcoat.
Poly Clad barrier gel system to prevent osmotic blisters below waterline.
Chemical bond (3M 5200) + SS Bolts (6" spacing) + massive Teak Caprail for Hull/Deck joint.
1/2" backing plates for deck hardware
Edson rack & pinion steering for superior strength and feel
Keel stepped mast
Factory installed systems (included in original base price):
isolated icebox, with light and icebox drain pump.
LPG locker for 2 tanks (10lbs each) with safety solenoid
3 burner stove with oven (LPG) (gimbaled), Model Seaward
Fresh water pressured system with PAR diaphragm pump.
Hot/cold faucets in galley and head
hot/cold shower
cold shower in cockpit
Dockside pressured (city) water input in cockpit
Blakes LaVac manual vacuum head with manual diaphragm pump( 2008 - as replacement for original Raritan PHII manual head)
Dometic/Sealand HTS holding Tank (2009 as replacement for original aluminum holding tank.
Whale MK 5 manual diaphragm discharge pump for holding tank discharge (2008 as replacment for original Jabsco electric mascerator pump)
3 way valves (2x) retrofitted for direct head discharge & holding tank discharge
all sanitation hoses replaced with Trident odor safe during retrofit (2008)
head raised by 2.25" with starboard raiser during retrofit (2008)
Atwood waterheater EHM6 (6 gal) operated by engine heat and 110V shorepower.
Monitor for fuel tank at nav station.
Monitor for fresh water tank at nav station.
Ample ventilation through multitude of hatches and portholes.
Florida Sailor
ODYSSEY
Old 07-07-2010
Volkhard's Avatar
Equipment List IP 37 Odyssey
While all Island Packets are nicely appointed vessels as they come from the factory, true customization takes place by adding sytems and instruments to the vessel. While the previous original owner of the vessel outitted her in 1998 during commissioning. some of the systems have been outdated when the current owner bought Odyssey in Summer 2007. A intensive refit took place between Summer 2007 and 2008
This list shows all items/systems added to the vessel in addition to the factory standard equipment.
Instrumentation & Navigation (total refit 2007/2008)
SIMRAD IS 12 Speed / Log
SIMRAD IS 12 Depth
SIMRAD IS 12 Wind
SIMRAD AT 10 Universal Converter (NMEA 0183 to SimNet)
SIMRAD / NORTHSTAR Chartplotter M121 w. GPS Antenna
12" full color screen with dual slots for Jeppenson SEAMAP max chart modules (SD format)
connected to Simrad intruments,
connectivity to SIMRAD Radar or new SIMRAD HD Radar. for full overlay or screensplit, just add radar dome. (radar dome not installed)
connectivity to AIS module via NMEA.Show other vessels right on the big 12" screen (AIS transponder not installed)
All instruments and Chartplotter installed in Nav Pod at the helmstation
SIMRAD AP 25 Autopilot
SIMRAD HLD MK2 Hydraulic Linear Drive
SIMRAD RFX Rudder Feedback
SIMRAD RC 36 magnetic Fluxgate Sensor
SIMRAD TI 25 Thruster Interface (connects Autopilot to Bowthruster for automatic positioning at rest)
SIMRAD WR 20 Remote Commander manually control the rudder from any point on the boat. Remote controll the
Autopilot. See the output of all instruments (depth,speed,wind,course (fluxgate). Control and use the Simrad VHF radio.
Link your cell phone and leave it in the cabin while using the WR 20 instead.
Communication and Entertainment (total refit 2007 / 2008)
SIMRAD RS 86 VHF Radio System with full class D DSC (Digital Selective Calling) , weather watch and Distress Alert call function. Installed at Nav Station in salon.
BOSS MR 1520W Marine stereo with CD. installed at NaV station in salon. MP3 capable.
BOSS Remote control with all functions (incl. MP3) installed in cockpit.
Speakers installed in cockpit and main salon.
Electrical System (total refit in 2007/2008)
Batteries: total 770Amp/hr
Housebank 2 x Lifeline AGM D8 with 255 Amp/hr ea.
Starting 1 x Lifeline AGM 27 with 100 Amp/hr
Bowthruster 2 x Lifeline AGM 24 with 80 Amp/hr ea
Xantrex Freedom 20 Charger & Converter
Xantrex Link 2000 Battery monitor system
Xantrex Link 2000R regulator module
Hearth Echocharger
Xantrex galvanic insulator transformer
Lights: most lights are upgraded to LED in 2009 (exterior) and 2010 (interior)
Bow-lights (starboard and port) Attwood 3550 LED (2009)
Stern-light upgraded to LED bulb (2009)
Anchor-light upgraded to LED bulb (2009)
Nav table light: Dr.LED Nighthawk chart light (2009)
Interior ligths upgraded to superbright LED bullbs (2010)
Windlass LEWMAR Sprint 1000 (2009)
new Windlass foot switches : July 2010
Bowthruster SIDEPOWER SP 95Ti (installed in 2007) with joystick control at helm
Galley, Salon and Head
Nova Kool refrigeration system (installed 2005)
Aircondition : Cruiseair 15000BTU system with SMX controller.Reverse cycle heat. Ducted to salon, V-berth and aft cabin.I installed 2007
Tarpaan Microwave Oven (installed 2009)
Hella Turbo Fans (4x) : in Salon, Galley, V-berth, aft cabin
LaVac manual vaccum head (installed 2009)
SCAD electronic tank indicator for holding tank (installed 2009)
Sealand HTS 12 Holding Tank (installed 2009)
Trident odorsafe sanitation hose (all head & holdingtank hoses, input & output replaced 2009)
Other
Davids (Katomarine)
Dodger (navy blue; new in 2007)
Bimini & connector panel (navy blue; new in 2007)
Whiskerpole mounted on track on the mast. Easy to set, even singlehanded! No balancing of the pole and risky maneuvers. Using the spinnaker halyard and a fore and aft guy makes poling out the 130% genny a quick, safe and fun maneuver.
primary anchor : Delta 35# on 300' chain
secondary anchor : Bruce 35# on 30'chain 170' rope
Doyle Stackpack II with Lazy jack system for full battened mainsail (new in 2008)
SS screens on all portholes (new in 2009)
Swim ladder treads (starboard; new in 2009)
Runners for companionway slide (starboard; replaced in 2009)
Cockpit cushion Phifertex (new in 2010)
Solenoid for propane : new July 2010
Mastboot serviced and re-sealed : July 2010
Screens and covers for hutches.
Screen (zipper) for companionway
Brightwork exterior stripped bare and refinished new in July2010
Brightwork interior (washed, sanded re-oiled / re-varnished) new in July 2010
Cabinsole (sanded and recoated) new in July 2010
Stainless exterior (polished) in July 2010
Fiberglass exterior cleaned, buffed and waxed new in July 2010
custom fitted sheets with pillowcases & comforter for v-berth and aft cabin
Pots and pans
Safety gear : current flares,Life jackets, horn, fire destinguisher, MOB throwline
Docklines, Fender, Boat hook
Wheel coated for superior feel (colorwheelz.com), color sand, new in May 2010
Florida Sailor
ODYSSEY
Old 07-07-2010
Volkhard's Avatar
Some first photos, much more coming soon ....
Florida Sailor
ODYSSEY
Old 07-08-2010
Volkhard's Avatar
some quick pics take tonight. More (especialy interior) over the weekend...
Florida Sailor
ODYSSEY
Old 07-18-2010
Volkhard's Avatar
Some more pics
Florida Sailor
ODYSSEY
Re-naming the boat pirateofcapeann General Discussion (sailing related) 111 4 Weeks Ago 02:39 PM
New name (I know, I know) owlmtn Boat Review and Purchase Forum 13 12-13-2009 07:46 PM
1986 PS Dana vs 1998 PS Dana Droofus Boat Review and Purchase Forum 6 11-24-2009 07:39 AM
1998 Beneteau or 1981 Cabo Rico mathislaw1 Boat Review and Purchase Forum 9 10-15-2006 12:08 PM
1998 Jeanneau 42.2 For Sale svbabb Boat Review and Purchase Forum 0 08-29-2002 04:42 AM
