pre purchase survey - Page 2 - SailNet Community
Advertise Here
Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Boat Buyers & Sellers Forum
Old 07-05-2010
cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough cardiacpaul is a jewel in the rough
lets speak plainly for a moment...
using "someones elses" survey is dam stoopid.
YOU have no idea who commissioned it, or why.
YOU have no idea what was or was not knocked about.
YOU have no idea how thorough the surveyor was.
YOU have no recourse at all if something was missing.
I'll admit, not a heck of a lot goes cattywhompus on a Cat 25.
Bulkheads may be shot, deck may be soft, engine might be adding to the oil spill in the gulf, black water tank may be leaking, gas tank may have rotted away, standing rigging may be ready to fall down, running rigging and fitments might be ready to go over the side... no, not much at all.
(no, I don't want to do a survey, no, I don't give a rats patootie if yo get this boat, or another boat, or no boat.
no, I don't care how much your next ex-wives hoo-hahs cost, or what they look like, chances are, I've already seen 'em on the net. )
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
  #12
Old 07-05-2010
I see CP is back...
  #13
Old 08-05-2010
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
rgscpat is on a distinguished road
At some point, a boat will be simple or inexpensive enough that many buyers will accept the risk of going without a survey, but may elect to self-survey or bring along some experienced friends who aren't too close to the proposed transaction. Much depends on the buyer's expertise and comfort level.
Note that a basic pre-purchase survey may not include sea trials or engine testing or any rigging inspection that isn't easily visible from the deck or checking on potential tank or deck leaks that wouldn't be readily found without tearing stuff apart. And, for people who really want to check things out, there are options such as sending engine oil in to a lab for analysis.
  #14
Old 08-06-2010
I'd point out the Boat Inspection Trip Tips thread I started, as it will help someone determine if a given boat is worth going further on. The smaller and simpler the boat, the less necessary a survey maybe, but a survey can often save you money, since it can often give you a negotiating advantage.
  #15
Old 08-06-2010
Water Lover
Thanks for those tips
Sailingdog,
Yes, I definitely read your tips. Some of them are things I've done already and others are going to be done before any money or signatures come out of me. Thanks for providing those!
I did notice some rust weeping from the rudder, so that's an area of concern.
This boat model was known for gate valves on through hulls, so automatically I expect to be replacing the remaining ones. I'm a bit paranoid about keeping boats afloat and not ignoring the through-hulls, hoses, exhaust, and drains.
And if I do buy the boat, either I expect to get to put some of the price into escrow to cover the risk of things that can't be determined now or to buy the boat at a price that acknowledges my risks.
"Some disassembly required" could be this boat's nickname; not only is it on the hard but the interior is jam-packed with stuff. It'll take a while to dig through it and make room to check everything. The boat has been on the hard for three or four years, so I expect a moisture meter wouldn't be relevant, and perhaps the fit of drawers and doors might be a tiny bit off for a boat on the hard, especially since it's likely not perfectly level on its supports, which are on dirt.
So far engine and driveline all look good (and I'll want to get water set up to run the engine though I won't be able to put it under load on the hard), wheel & rudder response good, deck good except for bow pulpit bedding, sails are so-so, rig is something I need to learn more about since it's all disassembled pieces.
  #16
Old 08-06-2010
mitiempo's Avatar
rgscpat
A moisture meter is always relevant. Rainwater can do a lot of damage and just because the boat has been on the hard for 4 years doesn't mean that water didn't get in before that and rot the deck core.
Brian
You may post attachments
You may edit your posts
Pre purchase survey and mechanical inspection advice? Petar Gear & Maintenance 7 03-14-2010 12:13 PM
The Importance of a Pre-Purchase Survey Sue & Larry Buying a Boat Articles 0 10-06-2002 08:00 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
