02-02-2011
Welcome to Sailnet.
You really would be better off starting your own thread on this specific topic rather than posting off-topic and hijacking this one. Please read the POST in my signature to help you get the most out of your time on Sailnet.
Also, it would help if you said what you were planning on using the boat for, where you plan on sailing the boat, and what your rough budget for a boat is, since these factors can determine what boats are better suited for your use and sailing area. For instance, if you're planning on daysailing, then the Bayfield 40 is probably a lousy choice. If you're planning on cruising the Bahamas, a boat with a 7' draft would be a problem....etc.
Originally Posted by neverknow
We are considering buying a Bayfield 40. What advice can you give us about this model? Good/bad??
Thanks
