05-04-2011
What you may want to consider is how the boat of that size will act in blue water of the Atlantic. Specifically with swells with seas on top of them. The duration between swells can make a passage in a boat under at least one wavelength a really rock and roll event.
In my 36 with the typical Northern Swells we get in the Eastern Carib from about November to June it can be a real ride if your trip is more than a few hours. Speed of your boat is governed by boat length and sail area... smaller standard rig boats are slower than similar rigged larger boats... by an appreciable factor.
In your size boat, some passages would be rather long and with swells it could often be difficult. Of course any good sailor can generally make a passage in a small boat.... but normally not as comfortable or safely.
If you have not had the opportunity to sail in blue water.... it is different from lake sailing in far more than the depth of the water. The feel is very different in most conditions. You may want to take the opportunity to check it out before you jump off, with a charter in the West Indies.
I prefer a sailboat to a motorboat, and it is my belief that boat sailing is a finer, more difficult, and sturdier art than running a motor.... Jack London
