06-23-2011
Hello,
I have owned my 1986 O'day 35 (same as the 34, with the addition of a swim platform) since 2006. I have the M25, which is basically the same as the 5424. Those engines are very reliable and are supported by many companies today.
My engine does have an hour meter and my boat had about 3600 hours when i bought it. Now it has about 3850 hours and still runs great. It burns no oil and makes good power.
The original heat exchanger was a 2" diameter, which was later changed to a 3". Mine has a 3" (serviced last year) and always runs at 180 even when operating at 80% power with 75 degree sea water (about the highest we see on the Long Island sound). I guess that if you boat in an area with cold water the 2" HX would be OK, otherwise the 3" would be better. I don't know how much it would cost to buy a new HX, but at least they are easy to install.
At cruising speed (6kts, 2200rpm, 3 blade prop) I burn about .5 gal / hour.
Regarding engine lifespan, from what I have seen with these simple marine diesel engines, age and lack of maintenance is what kills them, not too many hours. If the engine is not maintained - cleaned, kept painted, rust treated, etc., the salt water marine environment will rot the oil pan, pumps, cases, etc. And then it becomes too expensive to try and keep the engine going. (IMHO) If basic maintenance is done - oil changes, filter changes, coolant changes, replace pumps that wear out, etc. maybe change a fuel injector every now and then, the engine should last at least 5000 hours before any real work is done.
Where in New England are you looking?
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
