07-19-2011
Originally Posted by jimq26
Whether you plan on cruising or racing, the boat won't let you down, and will be very competitive on the race course.
Maintenance is the key to any boat being in good shape. There should not be any problem with mast support, since it is braced by a huge piece of oak that is sealed under the mast step. I have never heard of any problems with that area. All rudders need to be inspected annually and sealed up where necessary. Here in the north, we remove the rudder before winter storage. We then store them upside down in a non freezing temperature to ensure no water is inside them. This advice was given many years ago by George Cassian (of C&C fame).
Grampian made nearly a thousand of the G-26 model. It has the interior volume of most 30 footers, and does comfortably sleep 4-5 people.
"Oil canning" is not a problem if proper maintenance has been done on the bulkheads. On any boat of that vintage, you should have already replaced the bulkheads with new ones (according to a reputable SAMS surveyor).
Great boats - enjoy!
As a former owner of a G26, which by-the-way was unfortunately totaled by a neighboring boat in a freak October storm on the Chesapeake Bay. Not sure what you mean by "proper maintenance" when in fact there where not enough bulk heads designed in the first place where the "oil canning" occurs. The support that you speak of under the mast on top of the mast is a aluminum channel for which the mast is stepped too and can be lowered by pivoting forward. Inside the boat there is a cross piece 90 degrees to the exterior aluminum channel. When that interior support cross piece starts to sag under continued loading there is no amount of adjustment that will take up the slack in the standing rigging. Either that cross piece has to be replaced/rebuilt or what we did was make a shim for the aluminum channel thus raised the mast to the original spec.
Our rudder post had a dissimilar metal bolt drilled and placed..possibly used to prevent the rudder from rubbing/foaling against the bottom of the boat which eventual caused serious electrolytic corrosion eventually almost caused total failure of the rudder stock.
Asking 13K on a boat of that age..I'd have second thoughts..but there is no mention as to what is included in the purchase nor the amount of restoration
