09-07-2011
I've got a similar Iroquois with a Yahama 9.9hp 4 stroke that would start, and run at idle, but stall when I went into gear and tried to give it throttle. Twice I had to pull the motor and have a pro fix it for me, both times it simply needed a carborator re-build/cleaning - then it ran like a champ. Issue was with the ethanol (sp?) they put in gas nowadays. I tried additives/stabalizers with some luck, but then found a amrina nearby that sells gasoline without ethanol. That's all i've used for two years now without any issue. I also buy only the gas I need, so the fuel doesn't sit for too long. Maybe you've got similar engine problem.
