Go Back   SailNet Community > General Interest Forums > Boat Review and Purchase Forum > Boat Buyers & Sellers Forum
Like Tree2Likes
  • 2 Post By bljones
Old 02-11-2012
CarbonSink62's Avatar
Load Bearing Member
CarbonSink62 is on a distinguished road
How bad does this keel separation look?
I'm looking at this C-25 and the starboard side of the keel is fine. The port side has three cracks each less than three inches long at the keel/hull join.
I'll attach the pictures and hope that works.
Does this look like a deal breaker?
I know that no separation is best and that this will need to be dealt with sooner or later. As long as it doesn't get worse, I think the boat is ok.
What do you guys think?
How bad does this keel separation look?-c-25-gilford-16.jpg   How bad does this keel separation look?-c-25-gilford-18.jpg
Zen Again
Catalina 25 #2818
Tide goes in, tide goes out. Never a miscommunication. You can’t explain that.
Old 02-11-2012
paulk's Avatar
paulk is on a distinguished road
Looks like something that needs to be scraped out, filled, sanded & painted. Check the keelbolts. You could try putting some water in the bilge and looking to see if it leaks out those cracks right away. If it does, you'll need to do a better job filling the crack, which may entail removing/rebedding the keel. Keel may have hit something to create cracks like that, or could have gotten jostled in the Travellift, or it could just be the different materials in the hull and keel doing their expansion/contraction thing at different rates, and making the paint split. Have a good local fiberglass guy take a look for you and tell you what he thinks. Our keel has similar cracks by the end of each season. We fill & paint. We already own the boat, though, and know what to expect. If we were looking to buy a boat with cracks like that, we'd want to know how bad a headache it was likely to be, before it became our headache.
Old 02-12-2012
It doesn't look all that unusual to me.. pretty normal for a used boat with a bolt on keel.
Due diligence and all that, but this doesn't look like a potential dealbreaker in and of itself.
1984 Fast/Nicholson 345
Old 02-12-2012
MarkSF is on a distinguished road
Next time you could upload the pics to Tinypic, select message board resolution, and paste the message board IMG code link into your post. Then this will happen :
Bristol 31.1
Old 02-12-2012
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
He'll go from a C-25 to a self-loading containership?
Patient and Xx Darkwing xX like this.
It's 5 o'clock somewhere:
Old 02-12-2012
Carbon, as Faster said, it's pretty typical. Check the keelbolt torque and if everything is snug, then no worries.
It does, however, give you a bit of a price negotiating point if you let the seller know you are concerned and have misgivings... y'know unless it was cheaper, thereby making the risk more acceptable.
Old 02-12-2012
Technically, I think that's a dry bulk carrier.
Bristol 31.1
Old 02-12-2012
Load Bearing Member
Thanks, guys; I'll let you know how it goes.
Anyone looking to buy a 1988 Catalina Capri 18 on a galvanized trailer? It's a sweet boat, but someone is moving up!
$4,200
I'm working on the equipment list and a real ad.
Zen Again
Catalina 25 #2818
Old 02-12-2012
Parley is on a distinguished road
Seems like the beginnings of the 'ol Catalina "smile". Very typical on these older boats. My old C27 had it. Cleaned it out. Tightened up keel bolts. Re-glassed. Barrier coat and bottom paint. That was over 3 years ago and she's just fine.
Chuck
"A Small Sailing Craft is not only Beautiful, it is Seductive and Full of Strange Promise and the Hint of Trouble"
E.B. White; "The Sea and the Wind that Blows"
Old 04-01-2012
DesertPirate is on a distinguished road
Re: How bad does this keel separation look?
The Catalina smile. Early boats did not use SS keel bolts and they WILL rust. The good news is it not too expensive to repair the forward bolts. The yard can cut out a notch in the keel, drill in a new keel bolt hole, bolt it in, and then repair the keel. I guess the yard could cross drill under the more aft bolts and drill down from the bilge to add a new bolt, or bolts. I had my 1978 Catalina 27's forward bolts replaced for $500.
Any ideas why there is a separation in this keel? waterant Boat Review and Purchase Forum 11 10-31-2009 05:05 PM
Keel Hull Joint Separation labestia General Discussion (sailing related) 2 06-06-2009 05:36 PM
Joinery Separation - Help mqh7 Gear & Maintenance 0 11-21-2002 08:21 AM
Joinery Separation - Help mqh7 Gear & Maintenance 0 11-21-2002 08:20 AM
Joinery Separation - Help mqh7 Gear & Maintenance 0 11-21-2002 06:55 AM
