09-26-2012
Senior Moment Member
Re: Phenolic Resin Hammer
Originally Posted by Saltonsails
I've read that you can use one of these hammers to tap the fiberglass around chain plates and engine mounts to determine if there is rot underneath.
The problem I have is where to find this hammer and is it really necessary for a preliminary inspection.
In other words, why can't I just tap the fiberglass with my knuckle (therefore no damage) and just listen to the result. A dull thud would indicate rot or moisture underneath, whereas a crisp report would indicate all is well.
The only reason I'm posting this is because I'm not able to find one of the hammers.
Is anyone able to help me out on this?
Thanks.
Decent tool stores should have them. Rapping with your knuckles won't work on all but the thinnest glass. I found this out the hard way. You can use a brass hammer but it can leave marks if you're not careful - that's the reason for phenolic.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
