What Boat And Why - Page 2 - SailNet Community
 12Likes
post #11 of 30 Old 06-03-2013
Re: What Boat And Why
I don't think I would ever "live" on a boat, but I could see myself doing a fair amount of cruising. If we are talking extended distances, a Gunboat 66 would be my dream boat. If we are talking extended durations, I would probably go with a Hinckley Sou'Wester 70. I am rich in this imaginary scenario, right?
anthemj24 is offline
post #12 of 30 Old 06-03-2013
Moderator
Jeff_H's Avatar
Originally Posted by lavidanueva View Post
Being possessed of the vast knowledge each of you has on the topic of sailing, what boat would you choose for extended cruising and live-aboard, and why?
Where are you going with this question. As written it falls heavily into the 'how long is a piece of string? category.
We all have our preferences that reflect our tastes, budget, crew, experience, venue, and so on. The boat I would want, would probably not be the boat that someone else might want, and vice versa. If money were no object, she would almost by definition need to be custom to get the mix of features that I would like.
Jeff_H is offline
post #13 of 30 Old 06-03-2013
s/v Tiger Lily
dvuyxx's Avatar
For example, this boat is customized to someone's taste:
shanedennis and Minnesail like this.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #14 of 30 Old 06-05-2013
Gunboat 66 fast passages huge room shallow draft with boards up. With twin engines I can handle it by myself if need be would be a lot of work though. I like some solitude but I also love to entertain when i get to port so the room would be nice. Nice and stable.
sailortrash is offline
post #15 of 30 Old 06-05-2013
Tim R.'s Avatar
Our current boat, a Caliber 40LRC.
Well constructed, fast(for a cruising boat), pretty, excellent layout for a couple and occasional guests. It has real steps leading down the companionway, a nice sized pullman berth. 2 sleeping cabins each with it's own private head. Huge tankage(fuel-210, water-175, holding-100) and a reputation for world cruising. Great value.
Sails very well in all conditions with slab reef main and cutter rig. Many sail options to choose from. Points very well(35 apparent) and will out-sail any IP of comparable size. Sails well in heavy air. She will generally reach hull speed pointing in 12-14 kts. Light air performance is pretty good too.
Displacement about 23,000. 5.5' draft with a cut-away keel and a skeg hung rudder.
Many off-shore safety features like a rudder stuffing box dam, reinforced impact zones forward and the holding tank under the anchor locker acts as a collision bulkhead that can be holed without allowing water into the boat. All fuel and water tankage is built into the hull in 4 separate tanks that also act as below WL collision bulkheads that can be holed.
Light and airy below with 7 opening hatches and 12 opening portlights. 6'5" headroom. Small cockpit and nice swim platform with pull down ladder.
Downsides: Small nav station, no bridgedeck(must use hatch-boards off-shore)
My wife and I have lived aboard in Maine with our dog for nearly 3 years now. We spend every weekend we can out sailing from May 1st to December 1st. We are both tall(me 6' and my wife 5'10") and out dog is medium sized(60lbs). Plenty of room for us to be very comfortable.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #16 of 30 Old 06-05-2013
outbound's Avatar
think all cruisers will answer their own boat or be actively looking for the "last boat". I just took delievery of my Outbound and write this as I'm flushing out the fresh water tanks. She is a total joy. Haven't slept on land since delievery. Features
wondeful sailor- averaged 8.3 and saw 11 9kt on trip up from Virginia. With solent, carbon pole, well thought out preventor system easy to stand solo watches. Went from single to double reef multiple times. With dutchman, single line reefing(low friction spec'd) reefing by yourself easy and not scary as you can do it from cockpit. Al winches powered. Interior a delight. Every thing your hand touches is solid teak. Been on 10 y.o. Outbounds and they look boat show new. 5 berths behind the mast and two in front. Although all berths have bungle boards or lee clothes found no need for them as off watch could always find a good place to sleep without them ( ran in 4-8'ers). More comfortable than my house. 200g water and 200g fuel placed under sole amidship. 800a house bank.Tanks fiberglass -epoxy coated inside and glassed to hull or integral to hull. 2 water, 4 fuel. No maintaince. No worries of corrossion like with metal tanks or cracking as with plastic. No keel bolts. Collision bulk 7' aft of bow. bow thusher tunnel forward of this bulkhead. We took nice hot showers during passage. Two heads. One for stateroom forward manual. One aft- electircal. Seperate large shower room with seperate drain. Two compressors one for frig on for freezer. AC and frig/freezer water cooled. Heat central hydronic webasto. Every detail perfect. every system reliable and low maintance. Throu hulls arranged with manifolds so less of them.I could go on for hours. Sorry it's just like I felt with my first true love except I know this one will last the rest of my life.
s/v Hippocampus
Outbound 46
outbound is offline
post #17 of 30 Old 06-05-2013
.... but are you happy with her???
Faster is offline
post #18 of 30 Old 06-05-2013
outbound's Avatar
Talking Re: What Boat And Why
yup
s/v Hippocampus
Outbound 46
outbound is offline
post #19 of 30 Old 06-05-2013
grumpy old man
What boat and why?
answer: any boat because they are fun.
Bob's Blog ....
bobperry is offline
The Following 2 Users Say Thank You to bobperry For This Useful Post:
outbound (06-05-2013), SHNOOL (06-05-2013)
post #20 of 30 Old 06-05-2013
casey1999's Avatar
Are they stepping the mast or raising the TV antenna?
casey1999 is offline
Tags
best boat , liveaboard
WANTED: BASIC BOAT BBQ. CHARCOAL IS OKAY, BEATUP IS OKAY, ANY BOAT BBQ - $25 seattle stephenronning Gear & Maintenance 2 03-30-2009 10:21 AM
Coast Guard finds missing boat, still searching for other boat - FayObserver.com NewsReader News Feeds 0 05-12-2007 12:15 AM
Coast Guard finds missing boat, still searching for other boat - Access North Georgia NewsReader News Feeds 0 05-11-2007 11:15 PM
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 05:15 PM
Coast Guard finds missing boat, still searching for other boat - Myrtle Beach Sun News NewsReader News Feeds 0 05-11-2007 09:15 AM
