Dinghys - SailNet Community
post #1 of 6 Old 06-20-2013 Thread Starter
Dinghys
I need to buy a new dinghy after mice ravaged mine while it was in storage. I need a roll-up dinghy, preferably with some kind of floor boards, hypalon, that will hold four people and accommodate a 10hp motor. Does anyone have suggestions? What company would be a good alternative to Zodiac?
ambitious/rubbish is offline
post #2 of 6 Old 06-20-2013
Asleep at the wheel
jimgo's Avatar
Re: Dinghys
Are you looking for new or used?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 6 Old 06-20-2013 Thread Starter
Re: Dinghys
I'm looking new. I'm trying to avoid a totally rigid hull to save weight on my davits, and to make winter storage more feasible. How are the inflatable air floors, I've had two previous dinghies, a 3 panel wood floor and a roll-up aluminum floor, and I definitely preferred the wood floor. Would a fully inflatable floor be comparable to the wood floor in stability/ comfort.
post #4 of 6 Old 06-20-2013
Re: Dinghys
Inflatable floors are lighter and more convenient that wood panels, obviously, esp if you plan to 'stow' the dinghy occasionally. It can be a challenge to get enough pressure in the floor section to make it adequately stiff. (though apparently there are now inflatable paddle boards that manage, must have some skookum pumps) Also given their location and abuse inflatable floors seem more prone to leaks/patches from what we've seen.
We use a slat-floor rollup but it's mostly stowed away. We use kayaks primarily.
Faster is offline
post #5 of 6 Old 06-20-2013
If weight is the concern I think you will find a rigid aluminum bottom dinghy lighter (at least I did).
KBuckley is offline
post #6 of 6 Old 06-20-2013
MarkofSeaLife's Avatar
Dock
Re: Dinghys
Go down to a dinghy dock and see what is most common.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
Kayaks and zodiacs and Dinghys Oh my... pistonbully General Discussion (sailing related) 4 05-03-2011 10:30 AM
Dinghys and where to put them? Duckwheat Cruising & Liveaboard Forum 22 10-17-2008 04:37 PM
Hard Dinghys out there? dsprygada Gear & Maintenance 13 08-29-2004 12:14 PM
Dinghys, where? mrey Cruising & Liveaboard Forum 3 03-05-2001 02:02 PM
Dinghys - inflatable vs rigid capedory30 Gear & Maintenance 5 01-06-2001 08:42 PM
