Full Keel - Page 2 - SailNet Community
 64Likes
post #11 of 242 Old 07-11-2013 Thread Starter
Re: Full Keel
Thanks Jon. I'm not sure why the OP is limiting himself to full keel boats. Why not look at some fin keel, more modern designs? There is nothing going on here that makes a full keel more appealing. Just the opposite. When the wind pipes up and it's gusting to 6 knots a nice modern boat will still move you along.
Didn't mean to mislead. We are definitely NOT limiting our options to full keel boats. It's just that I have absolutely NO experience with that design and was hoping for comments/advice from fellow sailnetters. Our Omega was a FAST boat but, due probably as much to our inexperience as her design, was pretty spooky if the winds got above 15 knots and the seas built to anything over 3 foot. However, when the weather was more tame, she was REALLY fun to sail! The P365, on the other hand, handled two gales in our crossing without scaring us too badly but was at a disadvantage in any winds less than 8 knots.
[/SIGPIC]Dave
Sailing out of Seward, Alaska
"Fight the good fight, holding on to faith and a good conscience. Some have rejected these and so have shipwrecked thier faith"
dave6330 is offline
post #12 of 242 Old 07-11-2013
Re: Full Keel
Look for a boat that has the potential to put up clouds of efficient sail but can be reduced easily.
ctl411 is offline
post #13 of 242 Old 07-11-2013 Thread Starter
Re: Full Keel
So you're recommendation would be a ketch or cutter rig?
[/SIGPIC]Dave
dave6330 is offline
post #14 of 242 Old 07-11-2013
Re: Full Keel
I loved my cutter, the new boat (gulfstar 50 ketch) gets trucked here in 5 more days. So not sure on the ketch rig.I like the idea of the rig, but I also like to use light air sails (drifters spinnakers) so looking forward to mizzen staysails. You can make slower boats perform it's just more work and the ultimate performance is lower.
Did you use any on your 365( mizzen staysails ect)?
ctl411 is offline
post #15 of 242 Old 07-11-2013 Thread Starter
Re: Full Keel
Ours was a straight ketch (vice a cutter-ketch) - hence no staysail. We used the mizzen occationally but, frankly (and I'm ashamed to admit) I suspect we flew the mizzen more for how it LOOKED rather than trying to squeeze more speed or balance the rig.
davidpm likes this.
[/SIGPIC]Dave
dave6330 is offline
post #16 of 242 Old 07-11-2013
Re: Full Keel
Google mizzen stay sail pictures. It flys off the mizzen mast.
ctl411 is offline
post #17 of 242 Old 07-11-2013
Re: Full Keel
Okay, What gives here??? Did somebody paint a big bullseye on Island Packet sailboats or what? It seems like every post asking "What kind of boat should I buy?" has someone making very disparaging comments about IPs. Mine will sail at 3 knots in 5 knots of breeze! One can state their opinion about various makes and models if they so choose; but it would lend to ones credibility to note that it is strictly an opinion based on little else but hearsay. There are many sailboats that provide great sailing characteristics and some that are not rated for "Category A Offshore Use." Intended usage of the vessel should be the main factor in decision making.
Seaduction is offline
post #18 of 242 Old 07-11-2013
Re: Full Keel
Easy there sea, I stated a specific example. Ip's are fine boats, the op asked about full keel performance and I regularly sailed with a 45 IP.
ctl411 is offline
post #19 of 242 Old 07-11-2013
Re: Full Keel
I didn't mention any names because there are other threads on here that contain worse comments that yours. When I read your comment, it happened to be the proverbial "straw" that did the camel's back in.
One of the nicest boats that I sailed on was a Swan 68 but it would be a piece of crap on the Chesapeake. (could have something to do with its 12 foot draft.) OK, we all know that a Frers or S&S design Swan is not a piece of crap, its design is perfect for its intended usage.
ctl411 likes this.
post #20 of 242 Old 07-11-2013
Moderator
Jeff_H's Avatar
Re: Full Keel
"Did somebody paint a big bullseye on Island Packet sailboats or what?"
Yes, Island Packet did when they chose the design approach that they did. Its simply a physics thing; huge amounts of wetted surface, a poorly shaped underbody, and foils, a dearth of sail area and an excessively inefficient rig proportion.
That is not hearsay, its just plain basic physics. And it is easy to quantify the relative impact of that design approach. When you look at the PHRF rating in any Region with light to moderate prevailing winds, the Island Packets are typically 60 to 90 seconds a mile slower than boats of an equal length, and 2 to 3 minutes a mile slower than more normal designs of an equal displacement. Those kind of number are huge difference in speed, and in cruising modes, slower boats generally do worse than their ratings might suggest. PHRF normally spots cruising boats a little time in racing mode, and so while these numbers may do Island Packet a 9-12 second disservice in racing mode but they clearly show that Island Packets are a bit doggie.
And that matches what most of us have observed out there on the water. In reality, my observations sailing IP's and observing 100's of them under sail for decades is that they really do not perform at the low end of the wind range.
While you may be able to crowd a large enough genoa on a Island Packet to close-reach at "3 knots in 5 knots" of true wind, that would result in an apparent wind of somewhere around 7 knots. In the same conditions a decent light air boat, i.e. one that is not a little doggie, without an oversized genoa, would be generating closer to 8 or 9 knots apparent wind in those same conditions and would be moving closer to 5 knots through the water, in other words doing close to the true wind speeds. And that is the precisely the point being made when people say, Island Packets are a little doggie in light air. But not only are they slow in light air, but they also make gobs of leeway compared to boats with more efficient keels.
In the end, what counts is you are satisfied with the performance of your boat, and that is a good thing for you. As such it should not matter to you when other speak of the relative capabilities of the IP's.
But when someone asks for a relative description of the performance of these boats and thier suitability for use in a predominantly light air venue, the alleged offshore capabilities of an Island Packet (I say 'alleged' since the A Offshore rating really does not really define the suitability of a boat for offshore use, just its likelihood of surviving out there) may be relevant for some, offshore characteristics were not the question being asked. What is relevant, is the observable light air performance, and IP's poor light air performance is easily observable by anyone who has sailed one in light air or seen them try to sail in light air.
JomsViking likes this.
Jeff_H is online now
Tags
full keel , light winds , puget sound , sailing performance
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 02:52 AM
Why I like a full keel JimPendoley Boat Review and Purchase Forum 32 01-27-2013 11:12 PM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 11:51 AM
