Hull Inspection - SailNet Community
 2Likes
post #1 of 13 Old 07-31-2013 Thread Starter
Hull Inspection
Looking at buying a 1971 Tanzer 22. It's selling cheap. The cabin, cockpit, rigging, sails, etc are all in great shape. You can tell this is a boat that was well looked after. However there's a little paint chipping on the hull above the water line and boat is in salt water. The owner has already said it will probably need new paint in a year or so. Is it worth paying a diver $150 to check out the hull and keel and take a video?
Thanks,
wanderlustjoe is offline
post #2 of 13 Old 07-31-2013
aeventyr60's Avatar
Re: Hull Inspection
What's cheap? You can probably do a one way haul out at a local yard for 150 bucks. Make an offer contingent on your inspection/survey... buy it and go sailing!
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #3 of 13 Old 07-31-2013
Re: Hull Inspection
If it's ready to sail and cheap enough to consider it disposable at the end of your season when you haul, (if it's toast), why not? If you plan to get all emotional and dump time and money into it, haul it and see if it's worth starting with that one.
Is it bottom paint chipping or a painted hull starting to chip ?
capttb is online now
post #4 of 13 Old 07-31-2013
Old enough to know better
Re: Hull Inspection
Is it this one?
1974 Tanzer 22' Sailboat
If so offer a grand and take your chances, if the sails and rigging are good.
miatapaul is offline
post #5 of 13 Old 08-01-2013
overbored's Avatar
Re: Hull Inspection
hire the diver to clean the bottom and look it over at that time. should not cost more then $60 for a 22' boat
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 13 Old 08-01-2013
Dirt Free
boatpoker's Avatar
Re: Hull Inspection
The bottom is the part that holds the rest of it up.
kind of important to take a look.
miatapaul likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #7 of 13 Old 08-01-2013
I don't discuss my member
Fstbttms's Avatar
Re: Hull Inspection
+1
A diver will be able to tell you little of value without first cleaning the hull. Hull cleaning rates vary widely region to region, but unless the bottom is extremely foul, $150 sounds a little steep, even including the video service.
MDBoatBabe likes this.
Fstbttms is online now
post #8 of 13 Old 08-01-2013 Thread Starter
Re: Hull Inspection
miatapaul - that's the one I was looking at.
Thanks for all the advice. I called a # of different diving services and the cheapest I could find was $150. I don't know if this is just Pudget Sound pricing or if I'm calling the wrong people.
Thanks for the advice folks. I guess I'll keep trying to find someone cheaper to clean the hull.
post #9 of 13 Old 08-01-2013
Re: Hull Inspection
I'm in a low rent district, but for $150, I could get a short haul for my 34 footer, and the yard owner would probably let me use his power washer to clean it. Then it's out of the water for a good inspection.
Catalina 34
chuck53 is offline
post #10 of 13 Old 08-01-2013
aeventyr60's Avatar
Re: Hull Inspection
Give Seaview boat yard a call and see what they charge for a one way haul and pressure wash.
Inspection of Yachts in the EU peikenberry Cruising & Liveaboard Forum 2 12-29-2010 04:27 AM
Inspection of Gib Sea 123 johnskipper Boat Review and Purchase Forum 5 12-28-2010 11:20 AM
Chainplate inspection josrulz Gear & Maintenance 35 05-14-2010 12:22 PM
Rig Inspection - DIY or Hire someone? Bene505 Gear & Maintenance 35 04-12-2009 07:15 PM
Inspection Help in Georgetown MD dworkman Boat Review and Purchase Forum 6 10-31-2007 10:08 AM
