Full or Shoal Keel on New Oyster 575? - Page 2 - SailNet Community
post #11 of 51 Old 08-04-2013
blt2ski's Avatar
Re: Full or Shoal Keel on New Oyster 575?
Just looked at the specs, there is a deep, shoal AND a Centerboard version which goes from 5.5' to 12' of draft. Could be a very good option for some!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #12 of 51 Old 08-05-2013
grumpy old man
Yeah, why let a little thing like VCG bother you.
5.5 ' sure, that'll work just fine.
Bob's Blog ....
bobperry is offline
post #13 of 51 Old 08-05-2013
blt2ski's Avatar
How about 5' on a 43' boat? We have a bene DS43 in the fleet, I can out point that on by some 10*. At a race afew weeks back, while they did the same 2 mile or so upwind leg in the same amount of time i did, they had to sail at least 50% more distance than I did! so not sure where the 40 secs a mile they have on me helps them!
sailing is fun, to me make it fun from your stand point. For me, the faster I can go, more upright etc is the way to do it, Deep keels make this and easier option than a shoal with a in mast furling like the 43ds I have mentioned. Or the C28II. THe T2's frankly do move along and those boats are hard to beat. They might have a bit of a gift rating, or since the owners have owned them for a LONG time, they probably know every current, how to set the sails perfect ea time etc.......
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #14 of 51 Old 08-05-2013
grumpy old man
There is no substitute for draft.
Bob's Blog ....
bobperry is offline
post #15 of 51 Old 08-05-2013
Is the PHRF on the particular boat in question actually different by 20-30 seconds per mile between the shoal and deep keel? If so, I get it. That would be a lot more than I expected. On my boat, I find it hard to image it would be the case, but I could be wrong.
However, I don't think cruisers do very many 2000 mile legs, with 50 to maybe 100 mile days being most common.
I guess the OPs answer will somewhat depend on what they mean by cruising.
Jeanneau 54DS
Minnewaska is offline
post #16 of 51 Old 08-05-2013
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by Rhammill View Post
I neglected to include the draft differences on the 575 in my original post...
Full keel is 8' 10", shoal keel is 6' 9".
Thx
NINE FEET!???
Hope you enjoy the carribean cuz you sure aint bringing that boat to the keys or Bahamas... And if you ever want to sell it, where would you sell it? Having a boat with that kind of draft would wipe out any buyers that wanted to use it in my neck of the woods.
I guess you know what my answer is. But in full disclosure, I hate 6 feet (what mine is).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #17 of 51 Old 08-05-2013
blt2ski's Avatar
SWAN 53 CB SM 48 48 48
SWAN 53 DK SM 30 30 30
SWAN 53 SM SD 42 42 42
Mcgregor 65 std keel -45 shoal draft -9 wing keel 15
J44 36 vs 45 for the WK
Islander Peterson 40 87 for DK 111 for the shoal draft
Gulfstar 60 48 to 57
Grand soliel 39 108 vs 120
catalina 400 117 vs 126
Bene Oceanus 473 78 vs 96
Not too many larger boats like this in phrf. If I were to look up IRC/IRS or one of the more common rating systems in Europe, I could probably find ratings for Oysters. In NQ where PHRF is king, no one else in the world uses this system too much.... hard to get comparisons. But the few I did find in larger boats, there is at least a 12-20 sec difference. Even Minne's boat is not listed, be it shoal or deep draft, as no one has raced it, or not enough have raced to get into the system to look up at this time.
One can see that there is a difference in speed. As I sorta pointed out, as did minne, if you only go 10-50 miles then hit a dock....probably not enough to make a big deal out of. If you cross oceans or equal for a 2-4 day trip......now things will change a bit!
I still say, if one needs shoal, yet wants the deep draft pointing ability, a daggerboard or CB would be the way to go. But many of those seem to be slower in ratings than a shoal is! Probably because the board does not carry a lot of the ballast, and MOST of it is in the upper keel area, so the thing is BOGGED down by a LOT more wt. Vs a deep vs shoal can be 300-500 lbs for a boat my size, to 3000-5000 lbs for boats in the 40's and 50 foot range. A bunch of added wt to get the same righting moment, then add in drift, lack of pointing........adds up, whether a person cares or not is another story.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #18 of 51 Old 08-05-2013
grumpy old man
Marty:
Problem is if we are comparing a 6' draft Oyster to a 10' draft Oyster you are NOT going to get the same Rm. I don't care what humungous shape that they hang on that 6' keel tip. You will never get the VCG of the 10' draft model. And just adding ballast will have it's own set of negative effects.
Go now.
Go deep.
Don't go to the Bahamas.
Bob's Blog ....
bobperry is offline
post #19 of 51 Old 08-05-2013
blt2ski's Avatar
Bob,
I would have no doubt there would be a BIG difference in 4' as to how much lead one would have to add. Hence why the CB versions of some of the boats have such a slow rating, the lead is probably all in the upper 2-3' of the keel per say, in the housing below the hull. Now that I typed all that giberish, not sure if it made sense.......hopefully it did.
Now if I could figure out how to make my current boat 6' deep! then put the lake rig on it......not sure what that would do to the rating or speed or what ever.....probably not worth it frankly, better to spend some money on a proper designed boat in the mid 30' range, wife would be happy as it is bigger, for me faster.........
If I could afford an oyster, not sure 4' would be an issue, or the putting a daggerboard like Icon has or some of the other larger boats in the Oysters class of boats. That would be my way to deal with this issue. Not that 10' here in the salish sea is an issue, other than Fishermans bay on lopez or slot going thru laconner. Even those places one could get a 10' draft thru them if one had to. FB would be the harder one! Since at 0 it is 5' deep or there abouts, max I have seen is 9', so 13' of water to deal with......hmmmmmmm.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #20 of 51 Old 08-05-2013
I think we can all agree that a 57ft Oyster is going to be a pretty fast and comfortable boat, regardless of keel choice. It's just a question of how fast for cruising.
BTW, I think Bob likes the boat for what it is. That's about all I could make of this.
Oyster 575
Jeanneau 54DS
shoal draft keel vs regular keel peterchech General Discussion (sailing related) 52 03-16-2016 03:42 PM
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 51 11-16-2013 02:52 AM
Full Keel vs. Wing Keel small boats Kyhillbilly General Discussion (sailing related) 4 07-26-2011 11:51 AM
Shoal draft keel versus regular fin keel GBurton Boat Review and Purchase Forum 21 08-17-2007 11:33 PM
shoal keel vs swing keel pelicanl Boat Review and Purchase Forum 0 02-04-2007 02:52 PM
