Old 08-19-2004
penthink is on a distinguished road
Auxiliary Power
Hello,
I am considering buying a Pearson 32 with an 11 hp Universal Diesel. I have been told that this is a terribly small engine for the boat, as I am going to use the boat primarily for coastal cruising. The displacement of this boat is about 9400 pounds. Does anyone have any experience with this or any like combination? Am I going to be horrified?
Old 08-20-2004
GordMay is on a distinguished road
Auxiliary Power
A common rule of thumb is 1 HP of engine for every 500# of displ.- hence this boat might be be better off with 18 - 20 HP Aux.
FWIW
Gord
Old 08-24-2004
obiec is on a distinguished road
Auxiliary Power
I had a 33'' with a 11 hp. It would hit hull speed and was very economical. But once I was setting the hook in 40 kts wind, I had a hard time motering into it. But it all worked out.
Old 08-24-2004
hamiam is on a distinguished road
Auxiliary Power
Depends on how easily the hull is driven. For example, a modern race boat doesnt need alot of power to get upto hull speed. I have a 34'' Nicholson with a 48hp diesel; we can hit 8+ knots in flat water. Yes, its probably overkill but I do like having the extra power when i need it.
Old 08-26-2004
BarryL's Avatar
BarryL is on a distinguished road
Auxiliary Power
Hello,
Many early Catalina 30''s were equipped with that motor. The consensis seems to be that if you use the motor primarily for leaving / entereing the harbor, the engine is sufficient. If you use the engine for cruising when there is no wind, and / or plan on motoring long distances, like in the IWC, then it''s not sufficient.
Barry
OMC Saildrive engine loss of power muckitymuc Gear & Maintenance 7 09-29-2009 09:43 AM
Cruising Power Boat - Advice Needed m000ve0ver Boat Review and Purchase Forum 2 12-24-2003 10:47 AM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
engine losing power newuser Gear & Maintenance 5 06-06-2002 09:00 AM
Sabre 362 auxiliary power geyser Boat Review and Purchase Forum 0 11-20-2000 03:26 AM
