Good deal? Need advice. - SailNet Community
 1Likes
post #1 of 16 Old 09-06-2013 Thread Starter
Good evening ladies and gents,
I've found a 1976 c&c mk II 29' sailboat for 5k. The interior is fairly nice and actually clean, which is unusual for that price range I've found. There's minor cosmetic wear and tear on the inside, but it does have some flaws. The diesel engine has a head crack, and the previous owner decided to epoxy it and paint over it and sell it to the current owner without revealing the flaw. So needless to say, the engine is done. The boat is missing pretty much everything you would need to get underway. There is no compass, no depth finder, no engine, no vhf radio, no wind vane or autopilot. Some of those things I recognize aren't strictly necessary, but are nice to have for longer trips (self steering systems). It once had a nice aluminum davit and dinghy, which were knocked off when someone new to boating ran into it while it was docked. Unfortunately that means that a new davit might be difficult to install since it damaged the fiberglass when it ripped off the davit. The current owner never got underway with the boat so I have no idea if there are other problems, perhaps with the sail or the mast or boom.
As it is right now it appears to be a comfortable live-aboard vessel and is great for anyone who wants an apartment. But I've also found a boat for a few thousand more that has all of the equipment, including working autopilot and engine, dinghy, radio, etc. - a 1981 yamaha 30.
I plan on using my boat as a place to live while I'm in the Navy and do some cruising around the bay and maybe a little coastal cruising and offshore cruising. Not a lot, just enough to test the boat and myself. When I finish my time in the Navy I'm planning on taking a few months to travel up the coast over to Greenland and Iceland then down to the UK to visit Ireland. If I'm still feeling adventurous at that point then the Mediterranean is just around the river bend as it were, and there's a host of countries to explore around there. I'm also considering very strongly cruising around the Caribbean for a bit as well, but which course I plot out will depend largely on who is going with me, or a coin toss.
I'm looking for advice from the salty gurus of sailnet. What am I looking at cost and time wise to set the c&c right? Would you go for the c&c over the yamaha 30? Would the Yamaha 30 work for my long term plans better than the c&c? Is there anything that pops out in your mind listening to my plans?
Thanks for your time guys.
-Brett
SailorBrett is offline
post #2 of 16 Old 09-06-2013
manatee's Avatar
Re: Good deal? Need advice.
How much sailing have you done?
A choice between a money-and-time sink -vs- a sailaway boat? Yamaha.
...unless you want to spend two or three hitches patching up the C&C.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
The Following User Says Thank You to manatee For This Useful Post:
SailorBrett (09-07-2013)
post #3 of 16 Old 09-06-2013
Asleep at the wheel
jimgo's Avatar
I agree with Manatee. Walk away from the C&C you described. You're looking at THOUSANDS in repairs. Easily what you're going to pay for the boat.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
post #4 of 16 Old 09-07-2013
no longer reading SailNet
Alex W's Avatar
The C&C is in my opinion the better boat, but a new engine is $10k or more, and it sounds like the boat needs another $2-5k of work pretty easily. A 1979 C&C 29 in really tip top shape would be worth in the $20k range in Seattle, which probably means it should be a lot cheaper over there.
Neither of these are ideal choices for sailing across the Atlantic. It's been done in similar boats hundreds of times, but they were intended more for coastal trips where shelter is never too far away.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
post #5 of 16 Old 09-07-2013
Early days to be making transatlantic plans....
The C&C may be the boat with better 'bones', however the Yamahas are well engineered and executed, with some nifty ideas and it's probably a bit roomier, though somewhat less conventional than the C&C. Yamaha 30s never seemed to sail to their ratings, if that's a consideration. The early Y30s also had the engine under the Vberth, it was later moved aft. The engine forward version was a bit of an anomaly, with the added complication of a long propshaft and it's attendant bearings and steady rests.
But as-is-where-is it's pretty much a no brainer... the C&C is a still-unknown quantity as far has how bad it might get. If the boat hasn't been 'out' in years there's probably some serious underwater issues to worry about too.
I'd go for the sail-away - but keep in mind there are lots more boats than those two and it's a buyer's market... don't be in a rush and look at plenty more.
SailorBrett likes this.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
post #6 of 16 Old 09-07-2013 Thread Starter
Thanks guys, that was along the lines I was thinking. I'll steer clear of that c&c. It had a nice feel to it, but when it was missing even the compass...it felt like it had been stripped down for parts and anything electronic was sold off.
I'm not making any transatlantic plans yet per se, but I know I want to cruise when I'm no longer bound by my navy contract and keeping that in mind I feel as though I should plan for the eventuality. It'll take a lot of time and money to get myself and a boat to where I feel comfortable taking her on that voyage.
post #7 of 16 Old 09-07-2013
Old enough to know better
Well the C&C sounds to be over priced by about $4500. for under $10 grand you should be able to find a good 30 footer. Not sure if this is the Yamaha you were looking at or not, but looks kind of nice. Small cabin with those wide decks, but I bet that is nice when sailing!
1981 Yamaha 30 sailboat for sale in Virginia
That vbirth mounted engine is kind of strange, but at least you have good access. Settees look like pipe births with cushions but otherwise the interior looks well done.
I think you should be able to find a good boat for that price with a bit more room. Keep looking.
miatapaul is offline
post #8 of 16 Old 09-07-2013
Senior Moment Member
SloopJonB's Avatar
I don't think I'd choose either of them, no matter how nice they were, to sail to Greenland, Iceland and across the North Atlantic.
SloopJonB is offline
post #9 of 16 Old 09-09-2013
Advanced beginner
emcentar's Avatar
If you are planning to live aboard, you might need AC and heat even more than you'll need a compass.
The current owner might be straight-up but it sounds like his previous owner was a piece of work. You don't want to find out, I think, what else got painted over.
1987 Pearson 28-2, Deale MD
emcentar is offline
post #10 of 16 Old 09-09-2013
thesnort's Avatar
This one might be near where you live: S2 Sailboat *** S2 9.2 CC *** 30' Cruiser
Frankly though, I'd look around for something 32 feet and above, like an Islander 32 or even a Cal 34. They would probably be a lot more comfortable to live aboard.
thesnort is offline
The Following User Says Thank You to thesnort For This Useful Post:
SailorBrett (09-10-2013)
Tags
buying my first boat , c&c , cruising , live aboard , yamaha
Is this a good deal??? neverknow Boat Review and Purchase Forum 18 02-09-2012 12:13 AM
Cascade 29 - Good deal/Bad deal? jcwhite Boat Review and Purchase Forum 3 04-24-2011 12:49 AM
Did I get a good deal? donhaller Gear & Maintenance 7 07-17-2009 01:49 PM
Is this a good deal? ckgreenman Boat Review and Purchase Forum 5 09-06-2008 09:40 PM
Good Deal?? CherylannJohn Chartering 3 12-31-2004 09:35 PM
