Iron Keel opinions - Page 2 - SailNet Community
post #11 of 12 Old 09-12-2013
Senior Moment Member
SloopJonB's Avatar
Re: Iron Keel opinions
That's pretty much the way it is with iron - Beneteau didn't do anything special there.
The bottom line here is lead is the best but iron is perfectly acceptable in most cases and even has some advantages, like the aforementioned bolt removal.
It's also a lot cheaper - that's why the euro builders use it so much.
SloopJonB is online now
post #12 of 12 Old 09-15-2013
Mechsmith
I don't like the idea that a boats floating, and my surving perhaps, is dependent on a heavy piece of anything bolted through the floor.
A well designed lead encapsulated keel is best. (escept perhaps for racing) Anything else is merely an economical substitute. What price economy. Only you can tell.
Seafarer 29 KCB
Mechsmith is offline
Iron keel bolts mjkane Sailboat Design and Construction 1 02-08-2009 04:50 PM
opinions re: epoxy vs. plastic hulls, lead vs. iron keels ArgleBargle Sailboat Design and Construction 33 08-12-2008 10:21 AM
iron keel Capt Jim Gear & Maintenance 9 09-24-2003 05:56 PM
Iron Keel jbanta Gear & Maintenance 5 08-28-2003 06:02 PM
Iron Keel help mrb2222 Gear & Maintenance 5 01-08-2002 03:41 AM
