11-13-2004
Sabre 386 or Tartan 3700???
I tool delivery of a new Tartan 3700 this past summer after extensive comparative ivestigation with the the Sabre 386 and the Jenneaus and Jboats. I wanted a high quality, high performance cruiser. So it came down to the Tartan and Sabre pretty quickly based on quality, accommodation plan and performance. Both are very good boats. The quality of the joinery was about the same. So were the accommodation plans; about the same volume, with the tartan having a bit better layout.
But the Tartan 3700 is just a far better engineered boat; the strength/weight ratio of the hull and deck laminates, and the carbon fiber mast made it easily the best choice. I visited both factories. The difference is that Tartan uses an epoxy resin system and a synthetic coring called Core cell, both of which are very expensive, but yield far greater strength and osmotic resistance in the hull laminate. The carbon mast is about 50% lighter with greater strength and stiffness than the metal ones used on the sabre.
But it all comes down to what you like; I liked the Tartan. It was an easy decision once the time was spent to look.
