Southern Cross 31 vs Westsail 32 - SailNet Community
post #1 of 4 Old 10-18-2013 Thread Starter
Send a message via Yahoo to Shipislandpirate
Looking for a Go Anywhere, Single Handed Liveaboard...Purchase price 30k.. 20k for improvements...Headed for the Islands and Beyond...Which would you choose? Why?
Thanks,
Shipislandpirate
Shipislandpirate is offline
post #2 of 4 Old 10-23-2013
Broad Reachin'
kwaltersmi's Avatar
Re: Southern Cross 31 vs Westsail 32
I like both boats, but would probably choose the W32 if space/storage is a priority since it's the longer, wider, heavier boat. Don't forget the SC31 has an Airex cored hull. I don't know enough about Airex to say if that's a plus or a minus, but something to be aware of nonetheless.
Since you said you'll be single-handing, you might also consider the smaller siblings (SC28/W28), as both are also proven "go anywhere" boats and should also be available within your budget.
Catalina 34
kwaltersmi is offline
post #3 of 4 Old 11-16-2013
You may want to consider the allied seawind mk1 or even the mk2 although im not a fan of the second. it was the first fiberglass boat to circumnavigate and while not roomy below, it is seriously heavily constructed and cheaper than a westsail and while a slow boat is probably a tiny bit faster than a westsail plus it has a ketch rig which is really easy to reef in heavy weather. Drop the main and continue storm jib and jigger. The first seawind to circumnavigate was repeatedly rammed by a whale who was apparently angry at it and it suffered only cosmetic damage no structural damage. Personally I would pick a contessa 32 over both but thats just because its boring to just sit there in light winds waiting and yawing back and forth. For your cruising style though the seawind would be a good choice or an h28 which the seawind is based off.
duchess of montrose is offline
post #4 of 4 Old 11-16-2013
Barquito
Barquito's Avatar
Agree. Why limit yourself to these two boats. There are a lot of safe boats that would do fine set up for single handed sailing. Going slow can be a (slight) safety issue. It exposes you to more weather b/c it takes longer to make a passage.
Valiant 32
Barquito is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-01-2016 11:48 PM
Southern Cross 28 seaworthiness vs Morgan 33 andersbro Southerncross 20 11-10-2013 11:29 AM
Hull # Location Westsail 32 Roughwater 33, Southern Cross 31, Aries 32 Jvisbeek Sailboat Design and Construction 4 09-16-2013 02:31 PM
Bobstay chainplate in a Southern Cross 31 wnor Gear & Maintenance 0 05-27-2013 09:00 AM
southern cross anneminix Boat Review and Purchase Forum 3 12-03-2006 12:42 AM
