Kaufman 47 cutter, anyone have anything on these boats? - Page 2 - SailNet Community
 13Likes
post #11 of 76 Old 11-07-2013
Re: Kaufman 47 cutter, anyone have anything on these boats?
I didn't get out west looking so I don't know that boat.
Unlike Jeff I liked my cutter rigs. Yes can be a bit of a challenge to get a big genny through the slot in light air. It will blow right by in a breeze. When the wind comes up more put the gen away and use the stay sail and full main. More wind start reefing the main. Much easier than changing out head sails. For real light air I put up a drifter on its own rope luff. I will most likely put a stay sail on my ketch.
ctl411 is offline
post #12 of 76 Old 11-07-2013 Thread Starter
formerly 'BoatyardBoy'
SailRedemption's Avatar
Bob, I wonder if all of the K47's were lead keeled or if he had his special ordered at the yard? I'll have to look where I saw the iron keel at. I think it was an old Kaufman brochure... Yea, I know the Chinese/Japanese cultures are very deeply rooted in honor/face/respect, to lose those is a very big deal to them in all aspects of life. I can imagine a keel pour is challenging, that is a lot of weight.
ctl, alright thanks.. That's what my understanding of a cutter rig was, the ease of reduction of sail without having to actually change a head sail immediately.
Jeff, I'd still like to know your thoughts on adding roach to the main would help with its proportion to the head sail? Add roach and a few battens?
SailRedemption is offline
post #13 of 76 Old 11-08-2013 Thread Starter
Just read over the brochure again.. I'm pretty sure the keel is lead. The centerboard version has lead keel so I imagine the full keel I'm looking at has a lead as well.
post #14 of 76 Old 11-08-2013
I put large roach on my cutter main it work out great. Make sure the sail maker puts the battens in from the luff where the roach hits the stay. I even had one of my stay sails built with battens for added area. My had my ketch main and mizzen built with a lot of roach. I have a pic of the ketch on my profile page.
ctl411 is offline
post #15 of 76 Old 11-08-2013 Thread Starter
Oh alright, thanks for the information. I saw the picture, and you do have a bit of roach on both. I see they are both fully battened as well.
post #16 of 76 Old 11-08-2013
priscilla's Avatar
There is a new book just out "Sailing A Serious Ocean" by John Kretschmer. His boat is a Kaufman 47, he has been all over the world with it, ( and also a very good author ).
Priscilla
priscilla is offline
post #17 of 76 Old 11-08-2013
Hi
The Lazy Lightning II is a Kaufman 47' It is a great go anywhere offshore cruising boat. I have had this one since 2001 and have been very happy with it(NO Teak Decks). Mine has been to Austraila. before I got it. They sail very well. I saw the boat you are looking at, it sounds as if it needs lotts of TLC(your getting it at scrap value or less). Feel free to Message me.
Jamie
LazylighningII is offline
post #18 of 76 Old 11-08-2013
Moderator
Jeff_H's Avatar
Originally Posted by BoatyardBoy View Post
Oh Doesn't the use of a cutter with the inner jib make it easier to power your head sails down since your headsail area is somewhat divided into 2 sails? Also, would a bigger main/more roach with smaller genoa help even out these proportions? Or maybe just a smarter/smaller cut genoa jib combo?
I have only raced on a CNC 34 with hank on jibs. Never used a roller furling before. Would you say this cutter rig is more for cruising or does it fit its racer/cruiser title?
-sent from sea via corked bottle
I respectfully suggest that you may not be correctly understanding the term 'Depowering'. Depowering does not mean the same thing as shortening sail. The term Depowering refers to changing the shape of the sail rather than the size of the sail. As you may know, in order to generate drive (forward forces) except when running, a sail must also generate side forces as well. Those side forces are why boats heel and make leeway. By and large, the rounder the sail shape, the greater the forces, both drive and side force.
As the wind builds you get to a point that the boat is going about as fast as it can and so generates excess drive. At that same time, it is also producing excessive side force and heeling.
One way to deal with that is to shorten sail. But a simplier more calibrated way, is to flatten the sail and reduce its angle of attack. The process of flattening the sail and reducing the angle of attack is what is meant by depowering. While large jibs can be depowered a little by tightening the backstay to take sag out of the forestay, and by tightening the halyard to flatten the sail, and by moving the jib car aft a little to open the head of the sail and reduce the angle of attack at the head, the options are far more limited than on a mainsail expecially on a boat with a 'bendy mast'.
What that all means is that you end up reefing and furling sooner. A cutter's ability to sail under the staysail and a reefed mainsail works great at the upper most end of the wind range, just before you need a storm jib and trisail. Where a cutter has problems is transitioning in the lighter end of the windrange and in venues where you need to tack more frequently.
But the inability of a cutter rig to be easily depowered, and its inconveince in situations where you are tacking and jibing with any degree of frequency is the reason that fractionally rigged sloops have pretty much replaced the cutter rig on modern cruising designs.
I am cutting and pasting this from my post on another discussion but it also talks about why I am not a fan of cutter rigs for coastal crusing after previously owning one for a decade or so and sailing on a bunch more.
Based on my experience, a cutter rig works well if you live in an area where the predominant winds are sufficiently breezy that you can typically sail using a Yankee so you rarely need to use a genoa, or if you do long passages where you rarely have to tack or jibe. But in areas where there is a high percentage of light to moderate winds, and where you tack and jibe frequently, a cutter rig is a serious PIA.
There are a range of reasons why this is so. First, the foretriangle on a cutter is generally proportionately bigger than that of a sloop. So you are starting with a bigger headsail to handle.
Big genoas tend to be less efficient than taller aspect ratio sails and so require more area to be able to generate the same forward drive. This means that the already bigger headsail due to the bigger foretriangle, needs to have a larger overlap in order to generate the same forward force.
In order to keep the slot of the working jib open, genoas on cutters normally are routed outboard of the shrouds. This reduces the ability to point as high. That means a lot more tacking when sailing in confined sailing venues. There are similar problems avoiding blanketing the headsails downwind meaning more jibing in confined venues as well.
And then there is actual work to tack a cutter. It is always harder to tack a genoa that has a large overlap than one without. In the case of a cutter, the genoa not oly has a lot of sail to drag over the shoruds but there is also a very large of sail area aft of the jibstay. If there is enough breeze, the genoa will blow through the slot, but that generally means that you have been forced to overstand the tack toget enough force to blow it through, and so you end up winching in a lot more line on a more heavily loaded sail. You also lose an excessive amount of forward speed in the interim. For that reason, some cutter owners will partially furl the genoa on the tacks.
Either approach is not a problem offshore where you time the frequency of your tacks by the day rather than the minute, but its a real pain in the butt when beating up a river where the quality of every tack counts. When I owned a cutter, I sort of got used to the issue, choosing to sail with the jib topsail in confined quarters whenever the breeze was even close to enough to move the boat with the smaller sail, rather than fight with the genoa. But that strategy also meant more frequent sail changes when the wind died down.
Jeff_H is online now
post #19 of 76 Old 11-08-2013 Thread Starter
Thanks for the detailed right up, Jeff. An I appreciate the clarification of depowering, I understood it and I think I had the terminology incorrect, but definitely gave me more knowledge.
With all this said, would the cutter sail similar to a sloop if the jibstay was removed and only left with the Genoa to tack? Would you lose performance or speed with the absence of the jib?
Also, since the genoa is so large, could you not get it cut similar to a sloop jib in order to point higher?
I am asking these questions because though I have raced mostly in the last 5 years I am still learning the technical aspects of sailing, which can be a lifetime of information. I appreciate the advice and I am reading as much as I can so please don't think I'm just asking to be spoon fed.
With the boat, if I get it, I would probably be cruising it more than racing. And if I raced it it would be long distance rates since the CNC34 I race on we use for can and Lake races. I have been wanting to do Isla Mujeres for some time but the cnc is not up to it.
Ronnie
post #20 of 76 Old 11-08-2013 Thread Starter
Yea, I have looked over his site. When I get into port I'll try to contact him and maybe pick his brain some. Though I could email him. And that book, and a couple others of his, is on my Amazon book wish list.
Originally Posted by LazylighningII View Post
Hi
Jamie
Thanks for the insight, I'll send you a pm for sure.
Pearson 367 Cutter vs Hunter Cherubini 37 Cutter coma01 Boat Review and Purchase Forum 7 02-16-2012 10:54 PM
Different types of Cutter rigged boats delecto Learning to Sail 5 10-04-2009 12:34 PM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 5 07-11-2007 09:33 AM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 3 07-10-2007 07:37 PM
Kaufman 50'' krisadams Boat Review and Purchase Forum 0 07-03-2001 09:45 PM
