09-29-2004
Super Moderator
nonsuch 30: weird or wonderful?
Very complicated question. They actually sail quite well in a pretty wide range of conditions. They point better than most people assume. In some ways they are a little easier to sail than a modern sloop as in turn the helm and tack, or turn the helm and jibe. Trim only one sail. On the other hand there are far more limitations on and fewer options for controlling sail shape.
All of that said, they do not sail as well as a boat that is more clearly oriented to be a performance cruiser, and if you care about performance they may not be the best choice. Also their extreme beam means that it can be hard to get a 30 foot slip that is wide enough and so you may end up renting a bigger slip than the 30 foot length would suggest. I also missed having the shrouds and backstay to use when moving around the boat, but then again you don''t need to go forward as often.
