- Quick Menu
12-28-2004
J-40 for Long Distance Cruising ?
Hi Jeff
You have said:
“This thread seems to have picked up topics like lint sticking to rolling tar ball. At the moment this thread seems to be wrestling with the relationship of displacement to strength, carrying capacity, and the relationship of displacement relative to the various aspects of seaworthiness such as initial stability, knockdown resistance, limits of positive stability, motion comfort, and the relative righting moments inverted or right side up.”
I don’t see it that way. This thread was about the qualities and eventual limitations of a “J40 for long distance cruising” and François has extended the scoop of the thread to a more global perspective, including not only the J40, but that type of boat ( light displacement 40ft cruiser racer). All the subjects you have mentioned have to do with the limitations or advantages of that type of boat, comparing with what is considered a typical passage maker (the kind of boat that is widely used for that kind of travel).
Jeff said:
“In terms of the current understanding of knockdowns, there are a lot of factors involved, enough to fill a book, but in terms of a roll over, the only consistent factor in determining the likelihood of a roll over and rerighting has been found to be the relationship of the boat''s beam to wave height.”
This implies that it is as easy to capsize a Bavaria 40 as to capsize the BMW Oracle (America cup)….Both boats have the same beam (4m), or the famous Star and Stripes, versus the Bavaria 36 ( both 3,6m).
Of course this is ridiculous, the Bavaria 40 weighs 8,3T and has a ballast of 2.9T with a draught of 1,65 and the Oracle weights 24 T has a ballast of 20 T and a draught over 4m, and if you look at the dimension of those sails you know that the Oracle has to have a massive righting moment.
I think that it fits better here what you have said about other thing:
Jeff said:
“I also think that this thread has suffered a problem applying broad generalities…… in a way that somewhat corrupts the validity of the points being made”.
Fact is that the forces necessary to produce a rollover in a determined boat can be measured very precisely as you can also measure precisely the force that a given boat will offer to being rolled.
Quoting what Nigel Calder (in a very good article about boat stability, published in the September issue of “Yachting Monthly”:
“The area under the positive part of a rigtning moment curve is a measure of the total energy required to roll a boat, while the area under the negative part of the curve is a measure of how much energy it will take to roll it back again.”
Quoting Dave Gerr in a good article about boat stability published in the October issue of”Sail Magazine”:
“Stability curves can also be constructed using the Rightning Moment ( Rightning Moment = Rightning Arm x Displacement).
The curve will look the same, but you should use RM when plotting different boats on the same scale of comparison. This will immediately show the difference between boats with the same Rightning Arm (GZ) but dissimilar displacements. Note that the area under the stability curve is much larger for the 26.866 pound boat than for the 19.190 pound Gerr 44, even though the boats have the same RM at all angles of heel.
This is because it takes more energy to capsize the larger, heavier boat and it is why bigger boats are (broadly speaking) inherently safer offshore.”
The RM, namely the Area behind the positive part of the Righting moment curve is the measure of the resistance that the boat offers to capsize and............
RM = GZ x Displacement
This shows that Displacement is responsible in equal terms with GZ in originating the force that prevents capsizing (Rightning Moment).
The other half of the equation is GZ (Righting Arm). The GZ results of the lever created between the CG (Center of the Gravity) and the CB (Center of Buoyancy) when the boat heels.
Without wanting to be too much technical about it, I would say that the two main factors to increase GZ are lowering the center of Gravity and Increasing Beam.
But it is fair to remember that both factors together only contribute as much to the capacity of the boat in resisting rolling, as the factor weight, only by itself.
Jeff said :
“The forces involved in roll-overs … are so huge relative to the displacement of a yacht, that the weight of the boat in question has been shown to have next to no bearing at all on the likelihood of a roll over …”
I have said in a previous post:
“Safety and seaworthiness are relative parameters; the one that is not relative is the sea, that giving the right conditions is capable of sinking any small boat.”
And you seem to agree, but those are rare circumstances, the ones when size or weight don’t count.
In normal circumstances if, to capsize a boat, it is necessary the lateral force of a wave two times bigger than one capable of capsizing a lighter boat, then the first boat is (broadly speaking) a safer boat. If, to capsized a boat, it is necessary a wave three times bigger than the one needed to capsize the smaller boat, then this boat is safer than the one that is capsized by the wave two times bigger than the one that is capable of capsizing the lighter boat…... and so on.
Jeff said :
“In the end all boats are compromises, and we each chose our specific compromises based on our needs, tastes and fears”.
I agree with that, if you change FEARS to SECURITY MARGINS.
And those margins depend on a lot of conditions: people involved (family), your obligations to others ( again family) etc.
I Think that even with a well prepared light (27ft) typical small coastal boat you have very good probabilities to accomplish an ocean passage. After all last year a guy with a 18 foot Hobbie Cat crossed the Atlantic, and the first man to cross solo the Atlantic (East-west) has done that in a 5m open sailing Dory….But I also believe, quoting an old captain,” that the oceans are paved with the bones of the optimistic sailors”.
Super Moderator
In response to Paulo''s comments:
With regards to Paulo''s opening comments:
I did not say that I thought that it was a bad thing that this thread picked up a whole range of other topics, just that it had gone far beyond the original topic which was the suitability of a J-40 for distance cruising. It is the serendipitous wanderings that often make life more interesting and educational.
Paulo said:
"This implies that it is as easy to capsize a Bavaria 40 as to capsize the BMW Oracle (America cup)….Both boats have the same beam (4m), or the famous Star and Stripes, versus the Bavaria 36 ( both 3,6m).
Of course this is ridiculous, the Bavaria 40 weighs 8,3T and has a ballast of 2.9T with a draught of 1,65 and the Oracle weights 24 T has a ballast of 20 T and a draught over 4m, and if you look at the dimension of those sails you know that the Oracle has to have a massive righting moment."
My statement does not imply that it is as easy to capsize a Bavaria 40 as it is to capsize an America''s Cup Class or a 12 meter. My comment would imply that assuming a Bavaria 40 has the same beam as an America''s Cup Class and a 12 meter, these three are equally as likely to be rolled over by a wave that is large enough to roll any one of the three. It needs to be understood that a roll over is different from a capsize and my comments were in response to a comment on roll-overs. For fully ballasted boats, only wave action can cause a roll over, and the only significantly consistent factor in determining the likelihood of a roll over is the height of the wave relative to the beam of the boat. There are some secondary factors that come into play such as the depth of the keel which means that the America''s Cup Class and the 12 Meter are more slightly likely to be rolled over than the Bavaria due to their deeper keels.
Factors like the LPS, area under the righting moment curve (with the boat inverted and its gear in its actual position as inverted), downflooding, and the like are significant in determing whether the boat is likely to re-right and survive. There major differences in the design of these three boats which would result in the likelihood of differing re-righting and survival results.
I do agree with Dave Gerr that when it comes to resistance to wind driven knock downs and the speed of re-righting, that the area under righting moment is critical. I would strongly disagree that "Displacement is responsible in equal terms with GZ in originating the force that prevents capsizing." While righting moment results from a calculation of the displacement times the righting lever arm far, in a practical sense, far and away, weight distribution relative to buoyancy distribution, is much more critical in determining the likelihood of a knocked down than a boat''s actual displacement.
I can explain this by using the example that I generally cite to debunk the ''Capsize Screening Formula'', if you visualize two identical boats, except that one has a 1000 lbs of weight at the top of its mast, the boat with the 1000 lbs of weight at the top of its mast has a greater displacement but it is significantly more prone to being knocked down and far less likely to re-right because of its weight distribution.
While I cannot imagine that anyone would intentionally place 1000 lbs at the the top of their masts, if you look at the sources of the added displacement typically found in heavier weight cruisers, the added weight is typically found in locations that do not help stability such as heavier interior appointments, heavier deck and topside structures, heavier spars and rigging, heavier mast mounted electronic components, rigid cockpit shelters, higher davit mounted- heavier weight dingies and motors, and the like. Cumulatively these can add a lot of weight while at the same time reducing stability greatly.
The reality of this was borne out in the STIX research project where heavier displacement cruisers were often found to gave greater drag relative to their stability. This meant that these heavier displacement cruisers ended up needing to carry proportionately larger sail area relative to their stability, which in turn made them more prone(rather than less) prone to a knock down.
Paulo said,
“The area under the positive part of a righting moment curve is a measure of the total energy required to roll a boat, while the area under the negative part of the curve is a measure of how much energy it will take to roll it back again.”
Here again, heavier displacement works against re-righting. With its greater moment of interia, and the fact that a heavier displacement boat is likely to float deeper in the water relative to its center of gravity requiring much greater energy to re-right, the heavier displacement boat is likely to require a longer period of time and more energy to re-right.
Paulo Said;
"In normal circumstances if, to capsize a boat, it is necessary the lateral force of a wave two times bigger than one capable of capsizing a lighter boat, then the first boat is (broadly speaking) a safer boat. If, to capsized a boat, it is necessary a wave three times bigger than the one needed to capsize the smaller boat, then this boat is safer than the one that is capsized by the wave two times bigger than the one that is capable of capsizing the lighter boat…... and so on."
The reality of wave driven knock-downs and roll-overs is that the forces are enormous, many times the comparatively small differences in displacement between one boat and another. You are correct in assuming that it is possible for one boat to have several times the righting moment of another (although again this is more a product of weight distribution and buoyancy distribution than actual overall weight of the two boats. For example, comparing a specific lighter weight boat with equal but deeper placed ballast than on heavier boat, the lighter boat could easily develop much greater righting moment and require a lot less force to re-right). But in studies of wave driven capsizes and roll-overs righting moment plays a very small roll as the over turning moments grossly exceed the righting moments involved as the weight of water and force of gravity acting on the boat are just so enormous. Using the current coefficients for wave impact, the impact loads of a breaking wave on a typical 40 footer is hundreds of thousands of pounds, easily overwhelming the comparatively minor 12,000 lb difference in weight between a very light and a very heavy 40 footer.
So, whether they are called fears or security margins, they represent pretty much the same thing; the choice of a boat depends on how much of a risk you are willing to take. But no matter what your fears or security margins, in an of itself, weight does nothing good for a boat. It does not make it more seaworthy, sturdy, comfortable, easier to handle, or stable, just heavier.
Respectfully,
01-06-2005
Sorry for the long delay in responding. Was on vacation.
Anyhow, our #4 was tiny - I am hipshooting, but would say maybe 60% or so.
01-09-2005
excellent thread. I have no opinions on the J40 at all...
but....
before I began the journey of boat purchase and refitting for extended cruising I had compiled a list of what I thought I would need for such a task as long distance sailing for a year or two. by the time the boat was completed, my thought process was dfrastically changed, it was no longer ''how much I need'', but was ''how little I can get away with''.
12-30-2008
J-40 for long distance Cruising
Hi
Does any body know of have completed installation of a cruising generator aboard a J-40
12-30-2008
Bombay Clipper
Oh Mr. Dog where art thou??????
Welcome to Sailnet Jrussell. Shortly a most esteemed SN member by the screen name of Sailingdog will come along and help you get more out of this forum. He may come across in a less than friendly manner but ignore his tone and focus on his content.
In the future please note the age of the thread you are responding to...for example this one is three years old. It might be best to start a new thread asking your generator quesiton.
12-30-2008
Jrussell—
First, you would probably be better served by starting a new thread regarding generators and J-40s, since that really isn't the topic of this one. Second, it is fairly unlikely that any of the posters, excepting Jeff H, will respond, since most are probably long gone from this forum.
I'd also highly recommend you read the POST in my signature to help you get the most out of your time here. It has tips on searching sailnet, writing a good post, etc..
Welcome to the Asylum...
BTW, this post was mainly written for the amusement of FarCry...
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Bluewater defined?
dch |
Learning to Sail |
44 |
07-29-2009 07:20 PM |
Cape Fear 38
goduke |
Boat Review and Purchase Forum |
24 |
06-21-2008 11:30 AM |
Bitchin Pardey Cruising Day
rogerhjonesjr |
General Discussion (sailing related) |
0 |
02-09-2004 12:51 PM |
buying first boat
jerrycooper14 |
21 |
04-23-2002 02:15 PM |
Cruising beginner
Seanmc |
Cruising & Liveaboard Forum |
3 |
01-22-2002 04:39 PM |
