I have had a Seawolf 41 for a year now, and I still love it, but there are a number of caveats. I purchased mine as a liveaboard, and there is something about the interior of the CT/Seawolf/Formosa that I find much more "homey" than most sailboats this size. But then I am not a cook, so I don''t mind the very small galley. I also love the look of the boat, and got a lot of comments on her looks (right now she is in need of a decktop paint job).
Having said that, there is a lot to what Jeff says. Although most of the problems on mine had long been rectified (new thru hulls and fittings, new aluminum mast, etc etc), I spent several weeks this summer repairing dry rot in the cabin top (my decks are fiberglass). In addition, I rewired the whole boat as soon as I got her, but then I have had to rewire numerous boats of all makes, wiring standards even ten years ago left a lot to be desired.
I have no where to go fast, so I don''t mind that she is dreadfully slow. I have a friend with a Beneteau 36, that has the same waterline as the Seawolf 41, and the only way I can keep up with him is on a downwind run where I can put up a LOT more sail (he doesn''t have a spinnaker)
Given the ketch configuration, the sails can easily be handled by one person, and I often sail solo. But it takes me as much time to set one sail as it takes to set both the main and foresail on a modern boat with roller furling. Again, I am in no hurry so I don''t mind, and it''s lots of good exercise
The boat tracks as straight as an arrow, I can easily balance the boats sail and let her steer herself. Maneuverability in the marina leaves a lot to be desired, especially in reverse. Some owners advocate making the rudder larger to give it more bite in reverse.
I haven''t had her in what I would call heavy weather yet (30 knots max so far), so I don''t know if Jeff''s comments on the heavy weather sailing aspect are correct. I have seen comments from others in the ct mailing list that the CT does well in heavy weather.
If you are looking for more information, check out the mailing list at https://list.sailnet.net/read/?forum=ct or send an email to ct@list.sailnet.net.
You can also check out the pictures on my website www.cafe-solo.us.
Success
Evan Smith
s/v Cafe Solo
